Hi!
I need to buy an eletronic load, to do battery test, psu test, etc.
I was in doubt with the korad kel 103, the kunkin kp184, and the in the low range there is also an east tester et5410. The first 2 devices seem to allow remote voltage sensing, while the the et5410 seem to not have this feature (maybe can be modifed cutting the traces where is the voltage feedback).
In this so low range, what's the less bad device?
Thanks!
