Author Topic: Keithley/Tek DMM6500 streaming troughput 16bit mode.  (Read 5512 times)
Offline miro123Topic starter
« on: January 23, 2024, 04:48:34 pm »
Hello TE expert,
I have one question related to Keythley DMM6500.
I want to use the multimeter to capture continues data in high speed 16bit mode.
What is the LAN throughput without loosing any samples.I need all data to be collected to PC for let say 1..2weeks .
The datasheet Page 11 table "Bus Transfer Speed " gives only average numbers for 1000 readings
Thanks in advance
Miro
Offline MegaVolt
  • Country: by
Re: Keithley/Tek DMM6500 streaming troughput 16bit mode.
« Reply #1 on: February 07, 2024, 12:56:29 pm »
60 kilo samples in second.
They have a PC application that can capture data continuously. They promise 60K/s
The following users thanked this post: miro123
« Reply #2 on: February 10, 2024, 05:12:01 pm »
Thanks I alredy received my DMM6500. I will try and test it using python via LAN interface. I already have it running on standart /low speed mode/ using RAW socket interface.
According to spec is "Average for 1000 readings with relative timestamp (binary) LAN 160,000Sps
Offline MegaVolt
  • Country: by
« Reply #3 on: February 12, 2024, 08:34:37 am »
Keep us updated on your progress.
Offline Wil_Bloodworth
« Reply #4 on: February 28, 2024, 02:07:05 am »
How’s it going with your testing on this?
- Wil
Offline bateau020
« Reply #5 on: May 28, 2024, 07:37:19 am »
USB will be faster. Keithley also says this in one of their docs (1KW-61357-0_DMM6500_Datalogging_Application_Note_080318). The LAN interface is 100BT only, the USB 2.0 interface can go up to 480Mbps.
Also see github.com:tektronix/keithley, in instrument examples/DMM6500/Streaming...
« Last Edit: May 28, 2024, 08:10:24 am by bateau020 »
