It's clearly not an 722-ME as the front panel is labeled or an -MD. 200 on the dials is about 200 pF and 1100 is about 1100. Dial not marked but usable to 1200 pF. Clearly not in the -M Minus family. The current 722-D goes from 25-110 and 100-1100, so doesn't match 100-1100, although the 722-D two terminal I saw mentioned might have been different. Catalog J lists 222's; K1 lists 722-D dual range.
OK, not Brasso, thanks for the warning, Wrenches. Silver polish? Deoxit? Fader Lube?
Hope I got the photos attached properly - have trouble with that every time.
John
