so find the LIC files on the C drive, if its a software license, it will be married to the HDD's Serial # ( you can change the HDD's Serial # ) , if for a card, it should be applied to the card..
I never seen upgrading the software to a newer version reduce the spec(s) of the card.
I thought as much too, from what I read here. However, that's what happened when did a clean install and upgraded to V05.90.
I did a search on the HDD from root for licence files (searched C:\*.lic) and came up with a few more. With the exception of one which was in a temp folder, they were in a source folder (C:\Agilent_DVD_Source\Licences). It just looked like copies of installation DVDs and licence files associated with them. Renamed it and the ALA application still worked, so deleted the folders and rebooted to be sure and it still worked as before. I uninstalled all the other software the other day so not sure if any of those would have stopped working or not, after deleting.
The only two licence files left on this HDD have the following feature listed. First one is the original licence file that I found previously and the second was in a temp folder.
FEATURE agilent agilent 0 permanent 1 SIGN="029D 4656 7DE4 26CA ...etc
FEATURE Option100 agilent 1.0 permanent uncounted HOSTID=DISK_SERIAL_NUM=1812d03d SIGN=3ED997A08FB9E
The licence manager shows no active licences.
Not sure why 500MHz and 32MB is activated in this V05.70 installation but not on a clean V05.90. In any case I'm yet to need 32MB of depth but I suppose it is good to know that it's available if I ever need it.
