Author Topic: Keysight U1273A heavily discounted at Fry's  (Read 10147 times)
Offline mrnukeTopic starter
« on: October 28, 2017, 09:53:54 pm »
I picked a couple up from Fry's for under $250 a piece. There are only a few left in stock.. I think Campbell, Palo Alto and Sacramento stores still have some in stock. Not sure about stores outside the bay area. Great deal if you've wanted to pick up those OLED display multimeters.
Offline texaspyro
Re: Keysight U1273A heavily discounted at Fry's
« Reply #1 on: October 29, 2017, 05:55:11 pm »
I would avoid the OLED display models like the plague.   The OLEDs deteriorate over time and become unusable... even if the meter is not used.   Plus they are not visible outdoors.  HP does not sell replacements.
There is a thread on the forum about finding a replacement OLED module, but so far no joy.  The closest replacement found so far displays the image reversed right-to-left.
Display failures are a major cause of otherwise excellent test equipment becoming useless...  VFDs, plasmas, and (many) LCDs all have age related failure modes and since the equipment uses customized displays, once the display fails, the unit is trash.
Online rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #2 on: October 29, 2017, 09:25:04 pm »
TBH, everything has a lifespan. The fact a unit can give you two, three or four decades of service work is quite good. As you said, all technologies have their achilles' heel and, if you like the visibility or appearance of OLED or VFD,  avoid using them simply due to their lifespan is foolish.
And yes, I do have LCD, LED and OLED units.
Offline texaspyro
« Reply #3 on: October 29, 2017, 10:05:30 pm »
And it's foolish to spend $250+ for a meter with a known defect that can limit its life to around 5 years.  I know a lab that had half a dozen of these meters and they are all now unusable... including one that was never used.
OLED displays are gorgeous, but are still not ready for prime time, even today.   The Pixel 2 phone OLEDs (the high end model) are showing burn-in effects after a week of use.  And those displays have a decade of manufacturing and process improvements over the 1273A displays.
Offline tooki
« Reply #4 on: October 30, 2017, 02:29:48 am »
Nonsense. I even provided a link to a supplier of a known-compatible replacement. The mirrored text is in someone’s attempt to use an (incompatible) LCD instead.
« Last Edit: October 30, 2017, 02:32:20 am by tooki »
Offline tooki
« Reply #5 on: October 30, 2017, 02:31:35 am »
Tell that to LG: their OLED TVs are holding up just fine, as are many other OLED products. It comes down to the specific display quality, not the technology as a whole.
Offline texaspyro
« Reply #6 on: October 30, 2017, 03:49:32 am »
My friend that bought an LG OLED TV did tell it to LG...  burnin and color/brightness shifts showing after a few months.  Modern OLEDs are a LOT better than earlier ones but they still seem to have issues.  The blue LEDs seem to be particularly troublesome.  The TV was fantastic looking when it was new.  I look forward to the day when OLED screens can be trusted to last more than a few thousand hours.
Offline Muttley Snickers
  • Cursed: 679 times
« Reply #7 on: October 30, 2017, 04:06:22 am »
The light that burns twice as bright burns half as long and costs four times its original value, that's if you are lucky enough to hunt one down.    :D ;D
Offline ebclr
« Reply #8 on: October 30, 2017, 04:13:08 am »
Offline texaspyro
« Reply #9 on: October 30, 2017, 05:06:41 am »
Yep,  test equipment displays are a pet peeve of mine.   Take, for instance, the HP-531xx freq counters.  They use a custom VFD display and, like all VFD displays, they have a finite life time.   HP used to sell a replacement VFD for around $75.  Wonderful... fair price... I'll take a dozen.   Now, when (not if) your display goes dim it will only cost you $1800 to fix it... they now only sell a complete front panel board.   It has the VFD, a $4 driver chip,  the footprints for the rubber button contacts, and a ribbon cable header.
I have a project on the back burner for a replacement front panel board using an generic graphic LCD and a cheap microcontroller... might cost as much as $50 to build.  I know of companies that scrap dozens of these excellent counters every year just because of weak VFDs and the stupid cost of replacements.  I'd love to build it with an OLED display, but, well, you know.
A few years ago I replaced the 2x20 LCD module in a Tek AWG.  The module used a standard Hitachi controller and used an EL backlight (that has a limited lifetime).  The replacement was an OLED version. It was truly awesome looking display... for a year.
Offline nowlan
« Reply #10 on: October 30, 2017, 07:20:59 am »
https://www.frys.com/product/7363154
Boo. No online shipping. They have a little search tool, postcode, etc.
edit: a few other models, say clearance.
https://www.frys.com/search?cat=-73850&nearbyStoreName=false&pType=pDisplay&fq=m10099998%20KEYSIGHT%20TECHNOLOGIES
« Last Edit: October 30, 2017, 07:22:35 am by nowlan »
Online rsjsouza
  • Eternally curious
« Reply #11 on: October 30, 2017, 09:46:58 am »
Anedoctal evidence, but that seems to me it may have been a defective lot. As another piece of anecdotal evidence, on the lab i work, several equipments have  OLED displays running for quite a number of years without fading. My own 2014 manufactured (2017 purchased) U1273A is holding quite well. Also, as bluekull mentioned, it beats the crap of almost everything else indoors.
The pixel density and update rate of a consumer equipment screen stretches the boundaries of the technology, which is certainly NOT the case for test gear. Any display technology has problems, even your own VFD examples or non-organic LED displays.
Offline chickenHeadKnob
« Reply #12 on: October 30, 2017, 02:24:35 pm »
What OLED can last even 2 decades! This is routine for plain old LCDs. Expected  lifespan for a multimeter greatly exceeds that for cell phones and other consumer crap.
The following users thanked this post: Someone, bdivi
Online rsjsouza
  • Eternally curious
« Reply #13 on: October 30, 2017, 03:15:54 pm »
<youtube video here>
Cool video, ebclr. However, I don't think this is a calculated move to obsolete the product but instead simply the use of a new display technology - like many others that have been used in the past with varying degrees of success.
You don't know how long current commercial OLED lasts. Nobody really knows as its track record is not long enough. I agree that maybe 20 years may be a stretch, but your guess is as good as mine at this point.
Offline Mr. Scram
  • Display aficionado
« Reply #14 on: October 30, 2017, 06:36:34 pm »
Why gamble when you have an alternative you know will last?
Offline cncjerry
« Reply #15 on: October 30, 2017, 06:50:18 pm »
I almost grabbed one of those at Frys in Sacramento but I have the 1252B and had heard about the OLED issue.  I've always had a problem with the 1252 in normal light though so maybe the OLED would be easier to see.
But for that price I think it is a good buy if you need another meter, like we always do.
Jerry
« Reply #16 on: October 30, 2017, 11:08:53 pm »
Guys, (and ladies)!  I posted this for individuals who would like the OLED version of the meter, but were otherwise unable to obtain it. I understand there are people who think OLED is an unproven technology, but it seems that the arguments brought here are meant to impose their will on those who like the OLED technology.
Now, I am certain there is a certain crowd who takes carnal pleasure in viewing LCD displays in direct sunlight. I however, would like to view the display for longer than the five or so minutes it takes the reflected UV radiation to permanently blind me.
The following users thanked this post: rsjsouza, tooki
Offline tooki
« Reply #17 on: October 30, 2017, 11:26:33 pm »
An early one or a recent one? I thought that reviews of recent ones (like, the past year or two) indicated very good resistance to burn-in, supposedly comparable to CRTs.
FWIW, my home cinema is built around a Panasonic plasma TV, the other "ermagherd burn-in!" technology, and it's almost 9 years old without a hint of burn-in. I watch enough vintage 4:3 pillarboxed TV that one could imagine the center area being worn out more, but I can't see any such damage, even when showing a blank white screen, and knowing where to look! So if there is any wear, it's below my visual acuity, and I'm really, really, really good at color.
Of course, my plasma is used as a TV, and the Apple TV settop box has a screen saver set, so it's living a normal life. Plasmas used as info displays in airports, digital billboards, etc. absolutely do experience burn-in, just like CRTs used for that. (And even some LCDs.)
Note that plasma experiences another effect, transient image persistence, which is sometimes mistakenly called burn-in. But it's actually a charge build up in the pixels, and it manifests as the opposite of burn-in, in that those pixels get stuck slightly brighter than they should be, whereas burned pixels lose brightness. But this goes away after a few minutes, or by just playing some video to exercise the panel.
Offline swixo
« Reply #18 on: March 27, 2018, 02:50:13 am »
Just bought one of these meters today at Frys,  They have them left in Palo Alto only as of now at $240.  New in box.
a few warnings:
1. The software is v1.9, 3 years old.  You need the IR adapter $30 more to flash it.
2. The "Protective" plastic on the display was stuck on so hard that the GOO was left behind and will be
  difficult to remove - these meters look to be manufactured in 2015, so they have had time to get stuck.
Otherwise things look pretty good with it.
At $240 - cant complain too much, but I wish Keysight had done a better job with the display film.
s
Offline wraper
  • Country: lv
« Reply #19 on: March 27, 2018, 03:44:14 am »
a few warnings:
s
Bummer, if it's that old, it has EMI susceptibility issue. Keysight gave free replacement multimeter and you could keep the old one. Offer ended on 31-Dec-2017
« Reply #20 on: March 27, 2018, 04:35:12 am »
What? I thought I cleaned out the Palo Alto store a few months ago. I'm happy I missed some, so others can get in on the deal.
As far as the EMI issue, I think the fix was to replace some ferrite beads with zero ohm resistors. Dave has a video on it.
Offline lowimpedance
  • Watts in an ohm?
« Reply #21 on: March 27, 2018, 04:56:36 am »
And the resulting thread where forum members did the mods. has all the info needed.
Note however that the mod will affect the OHMS cal. And you will have to complete the full OHMS function cal. not just a zero to correct for it.
If you can live without doing the OHMS cal. then no problem.
Offline bson
« Reply #22 on: March 27, 2018, 06:00:12 am »
Green, red, and yellow OLEDs are extremely long lasting.  It's blue that's problematic.  This is why RGB displays used to color shift and burn in patterns, but a green, yellow or red monochrome display isn't going to have that problem.  This is from 2011 and blue has improved (TVs tend to overprovision blue and then adjust the hue as they age), but it's still not comparable to red, green, or yellow which are roughly on par with LEDs.  https://www.oled-info.com/udc-pholed-material-performance-update-green-now-reaches-14-million-hours
Offline wraper
  • Country: lv
« Reply #23 on: March 27, 2018, 08:42:15 am »
Not every oled display is equal. Display used in 1273 is early design, therefore has short life.
Online rsjsouza
  • Eternally curious
« Reply #24 on: March 27, 2018, 11:45:06 am »
The reported issues in another thread were on U1253, which are even earlier designs. Apart from texaspyro's report, I don't recall anybody else with issues on U1273. Besides, if the problem is focused on the color blue these displays are yellow monochrome.
BTW, mine is still going strong (used daily). I hope it stays that way. :)
