I found a news release on it and it appears to be brand new to the market.
Quoted prices converted to USD:
8 Channel $22,150.95
4 Channel $11,557.02
https://www.iwatsu.co.jp/newsrelease/2020/201130.htmlDigital oscilloscope Wideband 1GHz, high resolution 12bit, maximum 8 channels DS-8000 series 6 models released
November 30, 2020
Iwatsu Electric Co., Ltd. (Headquarters: Kugayama, Suginami-ku, Tokyo, President: Toru Nishito) will release the DS-8000 series of digital oscilloscopes (maximum frequency band 1 GHz, vertical resolution 12 bits, maximum input 8 channels).
In recent years, devices such as power supplies, inverters, and non-contact power supplies incorporated in car electronics and home appliances have been reduced in size and loss by utilizing next-generation power devices such as SiC and GaN. In order to make these evaluations accurately, it is necessary to accurately measure high-voltage and large-current signals at high speed with high resolution. To meet these needs, we have developed the DS-8000 series of digital oscilloscopes. In addition, there is high demand for high-speed, high-resolution, multi-channel measurement in a wide range of fields such as mechatronics and physical measurement, and it is useful in various measurement scenes.
Product name
Digital oscilloscope DS-8000 series
Main specifications and features of the DS-8000 series
-Display: 15.6-inch Full HD With
high visibility, you will not miss the details of the waveform.
-Easy-to-use user interface
Intuitive touch screen and buttons and knobs allow comfortable operation.
-High-speed startup for about 30 seconds
After turning on the power, you can start using it without the stress of standby time.
-Number of analog channels: Select from 2 types of 4CH / 8CH
Ideal for measurement of three-phase inverters and car electronics field equipped with multiple sensors.
-Frequency band: Select from 3 types of 1GHz / 500MHz / 350MHz
Ideal for designing and debugging high-speed signal circuits.
-Maximum sampling speed: 5GS / s
High-speed signals and steep signal changes can be reliably captured.
-Vertical resolution: Always
captures minute changes contained in 12-bit (equivalent to 16-bit in high-resolution mode) large-amplitude signals.
-Maximum memory length: 120M points as standard equipment Achieves
long-term waveform observation without slowing down the sampling speed.
-High-speed data transfer:
Optimal for high-speed transfer of waveform data for simulation and improvement of tact time of production equipment about 15 times compared to our conventional products.
DS-8000 series model list
frequency band
Number of analog channels Maximum
sampling
speed Maximum memory length
1GHz 8CH 5GS / s 120M points
4CH
500MHz 8CH 5GS / s 120M points
4CH
350MHz 8CH 5GS / s 120M points
4CH
standard price
4CH model 1,200,000 yen (excluding tax) ~
8CH model 2,300,000 yen (excluding tax) ~
Release date
November 30, 2020
Start shipping
Mid December 2020
Contact
■ Customer
Sales Headquarters Second Sales Department
TEL 03-5370-5474
E-mail: info-tme@iwatsu.co.jp
■ Press
Public Relations Group , Corporate Planning Department
TEL: 03-5370-5112
E-mail: pr@iwatsu.co.jp
