Author Topic: Keysight U1272a DMM: Which PTCs in LOW Z Mode?  (Read 1737 times)
Offline ElektronikLaborTopic starter
    • YouTube: ElektronikLabor
« on: March 04, 2016, 08:58:36 pm »
Hello,
today I noticed, that when I measure 1kV with the U1272a DMM in Low Z mode, the DMM gets a bit warm on a certain area of the surface (42°C / 108°F).
This Area is exactly where the PTCs are mounted on the PCB. What is the P/N of that PTCs which are used for that function?
There are four PTCs; I presume they are connected in series?
I hope I don't overdrive them with 1kV?
You can see the PTCs on daves Video (Dave is pointing at them); unfortunately they are heatshrinked.
BTW: The PTCs are drawing 1mA when 1kV is applied
« Last Edit: March 04, 2016, 09:11:30 pm by medvedev »
Offline electr_peter
  • Country: lt
Re: Keysight U1272a DMM: Which PTCs in LOW Z Mode?
« Reply #1 on: May 29, 2016, 09:54:46 am »
Checked U1272A connected to 230V AC mains on Low Z mode. After 20 seconds, surface temperature at the right of rotary switch reached 35-38 C and continued to climb at very slow rate.
Not an issue in my opinion, temp increase is minimal. Heat from low resistance mode has to go somewhere.
