Author Topic: Very weird problem with the BM235 select button  (Read 1473 times)
Offline aesteveTopic starter
« on: April 25, 2019, 06:24:48 pm »
Well, let's see if anyone can help me with this one.
The problem is that the select button doesn't change between different modes of each wheel position. In voltage, it is stuck at AC, in resistance, it doesn't change to continuity, in diode/capacitance, it it stuck at capacitance. Every wheel position is stuck in one mode. The weird part is, it is not the button. The button works fine. When I push it, it beeps, then the screen blinks as if it is changing mode, but remains in the same spot. It isn't some sort of double pulsation, if I hold the button the light turns on. And, on top of that, when I discovered it, I went through all positions in the wheel, testing the button in each position, and found that it changed once and then got stuck in whatever mode it changed to.
I've tried removing batteries for a long time (more than one day) but doesn't seem to reset it. Somehow, it remembers. Does anyone know a method to hard reset the meter? By the way, the firmware is revision D.
Re: Very weird problem with the BM235 select button
« Reply #1 on: April 25, 2019, 09:46:58 pm »
Welcome to the forum.
Try another set of batteries.
« Reply #2 on: April 26, 2019, 07:33:28 am »
Also tried that, nothing changed.
Offline shakalnokturn
« Reply #3 on: April 26, 2019, 11:15:06 pm »
Any chance a previous set of batteries may have leaked a little?
The QFP I.C.'s are not far behind, some contamination there could cause all sorts of weird things.
« Reply #4 on: April 27, 2019, 12:48:45 pm »
Nope, it's not that either.
I've noticed there is a jumper inside. I've tried shorting it and power it on. It doesn't seem to do anything.
Offline zerox123
« Reply #5 on: October 23, 2021, 03:05:23 pm »
I have exactly the same problem.
Select button beeps and long pressing enables the background light. But does not change to DC when in AC mode.
New batteries doesn't solve the problem.
Anyone knows a solution?
