So Fluke have a new Scopemeter, redesigned from the ground up according to them.The 40 MHz or 20 MHz bandwidth for the scope is perfected fine for the intended task, but that 40MS/s converter is so 1990's The recorder function has 400M point memory which is fine, but it seems the real time sampler only has a sample memory of 512 points. That's points.
