Since we're hosing the joint with conjecture, let me add some to the rain.
![Evil >:D](https://www.eevblog.com/forum/Smileys/default/evil.gif)
HPAK had a fire in which important equipment, including developmental test subjects, were involved. These test subjects, by definition, are HPAK IP, hence the wording of the letters written by... lawyers.
![Face Palm :palm:](https://www.eevblog.com/forum/Smileys/default/facepalm.gif)
I'm going to try and read between the lines A LITTLE here... not too far from reality, but a good "educated guess", as I've worked with a few such e-Cycler operations in the past here in Texas.
I suspect that also involved was some documentation regarding which of those equipment were experimental and which were merely old may have been involved, even destroyed. So rather than risk any of this gear exposing anyone to any of a dozen different types of potential hazard; by having been modified so they no longer passed their electrical certifications (ANY change in the UI, input or power supply sections can void these certifications; the restrictions of those certifications are by nature very... restrictive) as they were experimental gear, or by dint of possible fire-related chemical/hazardous material contamination, or possibility of both, they decided to clean house with a broad broom and destroy ALL OF IT.
Third-party contractor gets the job... some poor fool working there sees dozens of pieces of gear he can only dream of owning... not greed, but simply "knowing what it is" and cringing at the idea of sending it to its grave... decides to "rescue" a few pieces as if it were a dumpster dive.
This guy maybe then trades or sells away some pieces afterwards, and they find their way back into the regular service chain... units that were supposedly destroyed. Now EVERY UNIT on that list of destroyed goods is suspect... and if there is a potential hazmat contamination scenario, HP could seriously be in some deep doo-doo. But the kicker is... aside from that list, the documentation, particularly CoC, is not trustworthy.
Hence the drama as it is playing out right now, and the fact they can't say any more.
I also don't expect Daniel to conform or deny any of this "educated guess". Because he can't.
And I'm not going to pursue it any further, as it is entirely conjecture.
Have fun.
![ThumbsUp :-+](https://www.eevblog.com/forum/Smileys/default/icon_smile_thumbsup.gif)
*tzzt*
