Author Topic: Best oscilloscope for ~1500€  (Read 2803 times)
Offline VascoFerrazTopic starter
  • Country: pt
« on: February 11, 2020, 03:13:12 pm »
I have to to buy an oscilloscope and I need some of your biased :D opinion to make my decision.
The price range is around 1500€ and, if possible, I need the following:
- Bench oscilloscope
- Quality brand like Tektronix, Rohde & Schwarz, Keysight, Rigol...
- 2 analog channels.
- Bandwidth of 100MHz
- 8 or 16 digital channels
- Digital protocol decoding I2C, SPI, CAN, LIN...
- I don't need spectrum analysis.
If not possible, I have to forget about the digital protocol decoding :|
Thank you so much.
Vasco Ferraz
  • Country: pt
Re: Best oscilloscope for ~1500€
« Reply #1 on: February 11, 2020, 04:18:08 pm »
https://www.ebay.com/itm/193201819359
Thanks for your reply.
In fact, I already had this suggestion from Keysight Portugal.
Looks a very interesting oscilloscope but I believe it misses the software for the protocol decoding and the analog/digital leads
But it is a 200MHz 4 channel oscilloscope with 8 digital inputs.
« Last Edit: February 11, 2020, 04:33:03 pm by VascoFerraz »
Vasco Ferraz
Offline oewean
  • Country: no
    • Adroit.no
« Reply #2 on: February 11, 2020, 04:59:50 pm »
Have you checked out Siglent SDS2000X plus? A really nice scope, at a great price.
PS! I work for the Norwegian distributor of Siglent, so a little biased :-)
Norwegian distributor of test and measurement equipment....
Adroit.no
  • Country: pt
« Reply #3 on: February 11, 2020, 05:04:00 pm »
It is a very interesting scope.
I really need to review it a little bit deeper.
Vasco Ferraz
Offline Fungus
« Reply #4 on: February 11, 2020, 05:53:47 pm »
Keysight DSOX1204G.
Offline MadTux
« Reply #5 on: February 11, 2020, 05:54:52 pm »
A crappy, used $200 Rigol for now and patience to wait for some a good second hand instrument?
Then wait until something like a good 7k/8k Rigol or some high end Tek appears on used market for cheap.
Buying DSO is like buying computers, you get the same specs cheaper and cheaper the longer you wait.
« Last Edit: February 11, 2020, 05:58:03 pm by MadTux »
Offline alextwin007
  • Collector of mini test equipment
« Reply #6 on: February 11, 2020, 07:16:04 pm »
It's a fair lower then your price, but I was able to get a used Agilent DSO-X 2014A for 800 in nearly new condition.  The idea of getting a cheap scope and then waiting for a good deal may be worth it.  It even came with the DSOX2APPBNDL meaning I got the serial decode.  The only software I didn't get was the MSO option (So I am limited to my 4 channels) and the bandwidth upgrade.
Having a test equipment addiction is difficult when you don't have a lot of room.  The solution, only collect small adorable test equipment.
Looking for a tek 1401 / 1401A, if you have one message me
« Reply #7 on: February 11, 2020, 08:00:21 pm »
You said 2ch and there is the extremely well priced SDS2202X-E with all the features you need starting at just $619 plus the 16ch LA option.
Certainly not as nice as SDS2000X Plus with touch and 10" display however if you're on budget these compete well against KS 1000 series.
Just another one for you to swat up on.........
Offline KC0PPH
« Reply #8 on: February 11, 2020, 08:07:42 pm »
Rigol MSO5000 fits the bill.
Buy the 5072 and apply a Firmware "Fix" unlock everything. For the digital channels just purchase the probes and your good to go.
Its a new product and has some issues but there are long threads documenting the issues with the scope so you can make an informed decision if it will suit your needs.
Online nctnico
« Reply #9 on: February 11, 2020, 08:41:32 pm »
I'd skip anything from Rigol due to bugs. Siglent SDS2000X+ fits the price bracket without logic probes. GW Instek MSO-2104E costs less than 1500 euro (ex. VAT from Distrelec) and includes logic probes and decoding. It can also be upgraded to 200MHz and spectrum analysis mode with a key generator. Do yourself a favour and get a 4 channel oscilloscope if you are going to do development work.
« Last Edit: February 11, 2020, 08:43:35 pm by nctnico »
Online Martin72
  • Testfield Technician
« Reply #10 on: February 11, 2020, 09:11:48 pm »
Can confirm this, got one... ;)
The 4-ch Version (100Mhz) costs with VAT 1400 and it´s worth every cent.
Only con thing :
LA must be buyed optional, even when it´s hacked you need to buy the logicprobes and then it will be over 1500.
Rigol 5000 series I wouldn´t recommend at the moment, because:
Quote from: nctnico
The bugs aren´t so big you couldn´t work with the scope( got one for over a year), but their firmware-update reactions are very poor ( last update 6 month ago).
(Kierkegaard)
« Reply #11 on: February 11, 2020, 09:12:31 pm »
Certainly the SPL2016 logic probe is far better than anything ribbon cable based and we first saw these for SDS2000X then Siglent wisely chose to also use them for SDS5000X and now SDS2000X Plus models.
They split into two 8 channel pods via long and subtle flat cables.
https://www.siglenteu.com/accessory/spl2016/
Offline jake111
« Reply #12 on: February 12, 2020, 06:37:02 am »
Do you need the protocol decode for triggering?
If not, or if you could use a scope in conjunction with a very nice logic analyzer that also gives you the analog waveform, have you looked at the Saleae logic analyzers?  I have one and the software is just amazing and the analog + digital together is invaluable.
I gave up on protocol analysis on a scope except for triggering and even this is of limited use when either the logic analyzer has good analog capability, or can output a trigger signal for the scope.
  • Country: pt
« Reply #13 on: February 12, 2020, 04:51:32 pm »
Thank you so much for all the feedback.
Unfortunately an used oscilloscope is not an option because this is going to be bought by the company where I work.
The Siglent SDS2000X plus looks very interesting.
Vasco Ferraz
  • Country: pt
« Reply #14 on: February 14, 2020, 09:55:44 am »
The SDS2000X Plus Super Phosphor has already embedded the licenses for the following protocol decoding: I2C, SPI, UART, CAN and LIN?
I just need to buy the digital probes, correct?
Thank you so much.
Vasco Ferraz
« Reply #15 on: February 14, 2020, 10:08:16 am »
Yep all free and included the price. Trigger suites for each too.
And the MSO licensing.
So SPL-2016 (probes) and SDS2000XP-16LA (licensing).
For a full roundup of the options and indicative pricing in USD see here:
https://siglentna.com/digital-oscilloscopes/sds2000xp/#accessories
The following users thanked this post: VascoFerraz
  • Country: pt
« Reply #16 on: February 14, 2020, 11:11:01 am »
^ Thanks
Vasco Ferraz
