I have the DSLogic U3Pro16, which is identical to the U3Pro32 except for the number of channels. I haven't used the Intronix or the Digital Discovery, but at some point I have looked at them.
The Intronix and the DSLogic support external clock input, but the DSLogic one can only go to 50MHz, whereas it's 200MHz for the Intronix. The Intronix seems to have much better support for state tables, features that have been present in big iron logic analyzers from HP and Tektronix since the eighties. It's not very important for me: if I really need it, I'll use my HP 1670G. The triggering options of the DSLogic are not terrible, with the option do multi-state triggering with counters etc.
BTW, the DSLogic has an external trigger input pin, with associated probe wire, but that feature is currently not implemented, and I assume it never will.
The Intronix and the Digital Discovery have a very limited set of protocol decoders. The DSLogic has a truckload, and you can use PulseView if you want even more. This is a major plus for me.
The Digital Discovery only lists input voltages up to 3.3V. The DSLogic can go much higher, including 5V which is important for me because I have old 5V based test equipment that sometimes needs debugging.
The probe wires that come with the DSLogic are excellent: they're coaxial cables with a ground pin per probe wire. I expect the DSLogic to do best in terms of probing high speed signals. The Digital Discovery uses standard 0.1" Dupont wires but for $50 you can be a high-speed probe set consists of an adapter and twisted pair data/ground cables. Not as good as coaxial, but probably sufficient.
My biggest gripe about my DSLogic is that it doesn't do analog sampling, something the Saleae Logic Pro 16 can do. But neither can the Intronix or the Digital Discovery, and Saleae priced themselves out of the hobbyist market years ago.
I've been working for a while on a DSLogic teardown and review, but it's still incomplete. But if you're interested, here's the latest draft:
https://github.com/tomverbeure/tomverbeure.github.io/blob/dslogic/_drafts/2023-03-20-DSLogic-U3Pro16-Teardown.md.
