I'm new to the forum, but I've been following the eevblog YT channel lately, and that sparked an interest in electronics in me.
I used to have a cheap MultiMeter (actually I still have it) which I replaced with a Brymen 235 after discovering about it from eevblog itself.
As I'm trying to get rid of non-rechargeable batteries in my electronic devices, also because I fear leakage as someone suggested already, I'm using two Eneloop AAA batteries in my BM2335.
Today I was toying around with the EF functionality and from time to time the battery symbol appeared. It sounded strange to me that the batteries were already low, so I discharged them in the charger, and they still had ~630mAh (on a max of 750mAh).
I don't know if it's a quirk happening on the EF mode or what... my question, finally, is the following:
Is it OK to use rechargeable batteries with the Brymen 235 ?
cheers,
Danilo
