Thanks so much for the information
2. The LVDS buffer IC I'm considering shows that the output is done by sending current out of the +/- output pair and requires a 90 - 130\$\Omega\$ termination resistor across the output to generate the +/- voltage signal. My driver IC will run at 3.3 volts and my question is - is the termination resistor required or are resistors already there internal to the MSO5000 LA input?
It looks like there are 33 ohm series resistors. I don't think there is any internal parallel termination, but I can measure it later.
https://gitlab.com/riglol/rigolee/-/wikis/MSO5000-teardown
Hmmm, this is worrying. If the current driven out of the LVDS doesn't generate a big enough voltage across the 33
resistor then my whole approach isn't going to work without changing the internal resistors which I'm not going to do. I think the only thing to do is to get an LVDS IC (I'm planning on the
DS90LV047A) and try it from a breadboard to make sure it triggers the level changes accurately. It puts out a nominal 20 mA which, if driven across a 33
resistor, would give 0.66 Volts across whatever IC is receiving the signal. I looked at the GIThub tear down but couldn't see what that might be?
[EDIT] Oh, you said SERIES resistor so maybe if I include 100
parallel resistors just before the connector, they will feed through to the MSO5000 and work properly? Will need to test.
I have created the 50 pin connector component in Diptrace and the screen capture of it is below. Can anyone confirm what pin 10 is and whether the other pins are correct, particularly the Ps and Ns?
