Honestly speaking, as long as the devicevis within spec with the other ranges i see no reason to try and fix that specific range which you will rarely, if not ever use at that high of a frequency (assuming it's within spec for lower frequencies)
Also i saw that you have been asking this question in other parts of the forum and duplicate posting is frowned upon.
