If you run the signal through an R.C filter, you can easily remove the 40 MHz component, leaving the modulation envelope -- then you can trigger on the 1st 'wide' pulse.
Envelope is only in your eyes when you look signal on screen.
There is only pulse modulated 40MHz in this case here. If you attenuate this 40MHz there is - "nearly nothing".
Same if there is 40MHz AM modulated say with 1kHz. Scope screen you may see nice envelope, this "classic modulation image".
Amplitude of 40MHz is changing.
But there is not this 1kHz even when your eyes see detect its shape on scope screen.
It is perhaps more easy or other way to understand it if you look it in frequency domain instead of scope time domain.
Look it with spectrum analyzer. What you see. 1kHz and 40MHz... really. No not at all.
You see 39.999MHz signal, 40MHz(carrier) signal and 40.001MHz signal.
What you think you see if you set some low pass filter for remove this 40M rf.
Nothing, or more or less attenuated these same rf signals.
After modulating for get back this modulation signal you need demodulate. After demodulation you get back this 1kHz.
Simple AM demodulator is so simple as one diode + low pass and this scope trigger engine do not have it.
