Author Topic: SIGLENT SDG6000X Quick&Dirty Setup for Complementary PWM  (Read 1022 times)
Offline Le_BassisteTopic starter
« on: September 28, 2018, 08:17:10 pm »
needed a two channel complementary PWM with dead-time insertion to do some testing on a halfbridge switch-mode power stage.
although the SDG6000X (or SDG6022X for that matter) has two channels that can be set up for PWM individually, there's no straightforward way to actually program them to do push-pull with dead-time :palm: (hey SIGLENT: hint, hint...)
thought i'd share the setup with you.  see below a one-page cheat sheet. if you're too lazy to set it up manually, use the attached XML status instead.
(you have to change the file extension from *.txt to *.XML)
any suggestions welcome!  :popcorn:
« Last Edit: September 29, 2018, 02:08:10 pm by Le_Bassiste »
An assertion ending with a question mark is a brain fart.
The following users thanked this post: TurboTom, 2N3055
Offline bicycleguy
Re: SIGLENT SDG6000X Quick&Dirty Setup for Complementary PWM
« Reply #1 on: October 04, 2018, 06:20:22 am »
Would this also work with the SDG2042X ?
