Author Topic: Keithley DMM6500 ADC workings  (Read 1139 times)
Offline JelbertTopic starter
« on: April 27, 2022, 10:05:26 pm »
I'm planning to buy a new dmm and the Keithley DMM6500 looks perfect. When I read the datasheet it tells about a 16 bit ADC used in the scanning mode. An 16 bit ADC is not accurate enough to achieve a 6 1/2 digit readout. So how does this dmm work?
I asked at tek and the local distributor answered by sending the datasheet and not explaining at all. So how does it work? A dual slope ADC next to the faster ADC for fast scanning or only the ADC and some math interpolation trick?
Offline TiN
  • Country: ua
    • xDevs.com
Re: Keithley DMM6500 ADC workings
« Reply #1 on: April 27, 2022, 10:36:24 pm »
16 bit ADC is used for sampling/digitize function, while MS ADC used for 6.5-digit readings and normal operation.
Offline bdunham7
« Reply #2 on: April 27, 2022, 11:02:10 pm »
I think you have the terms a bit crossed.  The DMM6500 can take an optional multi-channel scanning card that lets it take readings from multiple inputs in sequence.  That is 'scanning'.  It would typically use the normal ADC--multislope with autozero--for that function, the same is it would for any normal reading.  The 16-bit ADC is for the high sample rate digitizing feature where IIRC it can take something like 1 million readings per second, but obviously with only 16-bit resolution.
« Reply #3 on: April 28, 2022, 04:43:02 am »
Thank you both,
I'm going to order this device. Yes I had the terms a bit crossed.
