Yes, I did have the Trigger in AC Input. Changing it to DC did bring back the Trigger Level display. For a few minutes, the trigger did not display correctly, but then seems to be working as expected. When not working, after centering the Trigger Level by pressing the TL knob and then adjusting the level manually, had incorrect trigger on waveform display. It may manifest itself when the Channel waveform is not in its default diplay position. (For this experiment of the scope, I was using the bult-in AWG with a simple 1 kHz Sine wave).
After all is said, it is working; however, I agree with BillyO, why does DC Coupling not behave properly?
Looking forward to the next firmware release.
Thank you
jdata
