Author Topic: SDS1102CNL vs SDS1102CML (100Mhz)  (Read 3485 times)
Offline 10101Topic starter
  • Country: pt
« on: March 25, 2015, 04:03:46 pm »
Could anyone say wich is the best and why please (if there is any relevant diference) ? :)
Thanks in advance
Offline BloodyCactus
    • Kråketær
Re: SDS1102CNL vs SDS1102CML (100Mhz)
« Reply #1 on: March 25, 2015, 04:36:31 pm »
I believe the CML has more memory, but still a pittance compared to the rigol 1054z
-- Aussie living in the USA --
Offline tautech
« Reply #2 on: March 25, 2015, 07:27:59 pm »
Thanks in advance
The only relevant difference between these models is the memory depth, 40 Kpts vs 2Mpts.
For other than detailed examination of a captured waveform it is unlikly you will see much difference.
Both models have 1 Gsa/s sampling that is shared between both channels.
The Siglent DSO range has an advantange over most compeditors with 400 V channel input ratings.
This means more safety for your scope if the need arises to examine HV waveforms.
Errors in usage also have a larger margin of error without damaging the scope.
« Last Edit: March 25, 2015, 07:39:10 pm by tautech »
