so, i have checked all the capacitors with a cheap ebay ers meter.
the values I read are almost similar 1800uF 0,13ohm ers at 50hz 0,6%vloss.
Is this ok or should I read a lower ers for these special purpose capacitors? (1800uF 200volt low ers caps.)
thank you
