Author Topic: UNI-T UTG932/UTG962 200MSa/s Function Arbitrary Waveform Generator  (Read 138618 times)
Offline valcher
  • Country: ru
Re: UNI-T UTG932/UTG962 200MSa/s Function Arbitrary Waveform Generator
« Reply #400 on: July 02, 2024, 04:19:31 pm »
I would like to clarify what the FPGA firmware is responsible for, the control interface?
Offline Yuriy V.
  • Country: ru
    • trengtor custom
« Reply #401 on: July 02, 2024, 05:33:52 pm »
Синтезатор (synthesizer)
« Last Edit: July 02, 2024, 07:48:33 pm by Yuriy V. »
The following users thanked this post: Markus2801A
Offline onx
  • Country: ua
« Reply #402 on: July 02, 2024, 11:03:06 pm »
This firmware UTG900E.bin doesn't have SRC check :)
We can change FW version to any we want.
Now my 3.06 changed to 1.09 :)
Offline Aldo22
« Reply #403 on: July 05, 2024, 12:03:34 pm »
normal or not ?? Is my copy bad?
I don't know enough about it and I don't have such a device, but why don't you compare the information in the data sheet with your measurements?
Like "phase noise" and "shake": https://www.batronix.com/files/Uni-Trend/UTG900E/UTG900Edatasheet.pdf
Offline Aldo22
« Reply #404 on: July 05, 2024, 02:32:44 pm »
because there is no value for shake at sine waves. And because I don't understand what a value of -125dBc/Hz means at phase noise.
I understand that you would prefer it if someone with an UTG932 could confirm your measurements.
I can't, but I think that some jitter is normal. It's still a cheap FG.
If you want to know more about it theoretically:
German: https://de.wikipedia.org/wiki/Phasenrauschen#Messung
Lots of background (English)
https://www.npl.co.uk/special-pages/guides/gpg68_noise
Maybe you could ask the question more generally in another subforum. Maybe "Metrology" or "Beginners", I don't know.
There are already such topics: https://www.eevblog.com/forum/metrology/phase-noise-measurement/msg3337416/#msg3337416
The following users thanked this post: Yuriy V.
Offline valcher
  • Country: ru
« Reply #405 on: July 08, 2024, 06:20:06 pm »
I seem to have found what the write error problem is, the new UTG900 has w25q64 memory, and the old w25q80 memory. And also, there is a slight difference - see the photo.
Now I can't confirm my guess yet, because there is no such memory, but I ordered it and am waiting for it.
« Last Edit: July 08, 2024, 06:51:17 pm by valcher »
Offline Yuriy V.
  • Country: ru
    • trengtor custom
« Reply #406 on: July 09, 2024, 09:11:58 pm »
Are the FPGA chips used in them completely identical?
Offline valcher
  • Country: ru
« Reply #407 on: July 11, 2024, 04:47:23 pm »
All chips are identical, only the FPGA itself is from different manufacturers.
My guess was not crowned with success, I tried to flash a new flash with a programmer, but it did not bring any effect. Moreover, I accidentally rewrote the native flash image and now I can’t revive the generator. If anyone can share the image.
Offline valcher
  • Country: ru
« Reply #408 on: July 17, 2024, 09:45:44 pm »
I found the original firmware and restored everything.
Offline Yuriy V.
  • Country: ru
    • trengtor custom
« Reply #409 on: July 18, 2024, 01:35:59 pm »
Version?
Offline valcher
  • Country: ru
« Reply #410 on: July 18, 2024, 03:15:41 pm »
Version?
FPGA - 1.07
Offline Yuriy V.
  • Country: ru
    • trengtor custom
« Reply #411 on: July 18, 2024, 06:04:37 pm »
Anybody has Software (firmware) version 1.09 BIN file?
Offline Evgeni62
  • Country: ru
« Reply #412 on: July 19, 2024, 04:01:20 am »
Does anyone have firmware with Russian language?
Offline valcher
  • Country: ru
« Reply #413 on: July 19, 2024, 05:42:50 pm »
@Evgeni62
It seems like this never happened.
@Yuriy V.
What is the difference between 1.09 and 1.07?
Offline Yuriy V.
  • Country: ru
    • trengtor custom
« Reply #414 on: July 19, 2024, 07:17:28 pm »
Scroll above, I posted a screenshot - and you will understand what I’m talking about.
Offline Yuriy V.
  • Country: ru
    • trengtor custom
« Reply #415 on: July 20, 2024, 05:31:20 pm »
Inrush Current when power switch moves to ON.
« Last Edit: July 20, 2024, 08:02:56 pm by Yuriy V. »
