Author Topic: Agilent MSOX2000 Digital Probe Pin Out  (Read 2409 times)
Offline rickstarTopic starter
« on: April 07, 2015, 06:45:20 am »
Hey Guys I am trying to adapt an IDE cables and some probes to build a home made MSO probe setup, for a MSOX2022A.
I found http://literature.cdn.keysight.com/litweb/pdf/5968-4632E.pdf
This is a great document and shows all the pin outs.
Does there need to be any capacitors or resisters in line to the probes from the MSOX IDE type connector?
« Last Edit: April 07, 2015, 09:00:02 am by rickstar »
Offline georgd
  • Country: cs
Re: Agilent MSOX2000 Digital Probe Pin Out
« Reply #1 on: April 07, 2015, 04:21:27 pm »
In same documet you can find passives in probe heads.
https://www.eevblog.com/forum/testgear/dsox2000-and-3000-series-licence-have-anyone-tried-to-hack-that-scope/msg365750/#msg365750
Probe axcts as 10:1 divider, series resistor 90.1k is mandatory!
Georg
