Author Topic: Keithley 2182A Digital Nanovoltmeter  (Read 5968 times)
Offline Terabyte2007Topic starter
  • It is purpose that created us... That defines us..
« on: October 21, 2013, 03:09:25 pm »
Does anyone have any experience with the Keithley 2182A Digital Nanovoltmeter? Is it worth the 3K price tag?
http://www.keithley.com/products/dcac/sensitive/lowvoltage/?mn=2182A
Eric Haney, MCSE, EE, DMC-D
Electronics Designer, Prototype Builder
Offline robrenz
  • Real Machinist, Wannabe EE
Re: Keithley 2182A Digital Nanovoltmeter
« Reply #1 on: October 21, 2013, 04:02:58 pm »
The Agilent 34420A nanovoltmeter/micro ohmmeter has a built in current source so it can do resistance without a separate current source but it costs a little more.  I don't know which one has better specs for voltage.
Offline branadic
  • Sounds like noise
« Reply #2 on: May 10, 2018, 09:40:59 pm »
Even though this thread is very old, yes it seems to be worth it's price. We have one at work and I have checked relative zero over 2h using the internal RS232 interface with a selfmade short. Both filters analog and digital are active, NPLC is 5. I have never seen Attovolt coming through an USB interface before.  ;D
-branadic-
« Last Edit: May 23, 2018, 07:44:23 am by branadic »
Computers exist to solve problems that we wouldn't have without them. AI exists to answer questions, we wouldn't ask without it.
The following users thanked this post: kj7e
Online Alex Nikitin
  • Femtoampnut and Tapehead.
    • A.N.T. Audio
« Reply #3 on: May 11, 2018, 12:32:28 pm »
-branadic-
How does it compare with the K181?
Cheers
Alex
« Reply #4 on: May 11, 2018, 12:54:16 pm »
-branadic-
Nice, I am afraid my lab may have too much background interference to accurately measure that low. I would need to build a shielded enclosure. I have a high resistance meter that will measure well into the TerraOhms but I have to use it with my DUT in a grounded aluminum box. Thanks for the info!
« Last Edit: May 11, 2018, 12:56:13 pm by Terabyte2007 »
Offline branadic
  • Sounds like noise
« Reply #5 on: May 11, 2018, 02:42:13 pm »
Can't tell you that, as I never recorded 2h data with Keithley 181, but you can get a raw idea of Keithley 181 performance in this video:
https://xdevs.com/cm/RandomPics/K181_Cable/20171009_194206.mp4
-branadic-
Offline kj7e
  • Damon Stewart
« Reply #6 on: May 11, 2018, 03:17:03 pm »
-branadic-
Looks like a CalMachine video.  Damn, now I want one and I don't even have a use for it.
Offline branadic
  • Sounds like noise
« Reply #7 on: May 12, 2018, 08:49:34 am »
It is a CalMachine video ;)
This piece of kit is really nice, but I'm lacking applications for it beside monitoring the difference between voltage references. Thus, I sold my Keithley 181 and if needed can use the 2182A we have at work.
The nice thing about 2182A is that it has 2 channels, even though the second channel has only 10nV resolution and a maximum input voltage of 12V. Good enough for ratiometric measurements like characterizing voltage dividers without necessarily rearranging probe tips.
-branadic-
Offline TiN
  • Country: ua
    • xDevs.com
« Reply #8 on: May 13, 2018, 03:40:29 am »
I can part with 182M as I got 2182A as repair project already  :)
Offline kj7e
  • Damon Stewart
« Reply #9 on: May 13, 2018, 03:56:32 am »
You have the fancy connector for it?  The 182 may be more than I'm willing to spend.
Offline TiN
  • Country: ua
    • xDevs.com
« Reply #10 on: May 13, 2018, 04:02:31 am »
Yup, complete kit. I even have Keithley 1488 short.
I recalibrated it a week ago, using 5700A/3458A.
Offline kj7e
  • Damon Stewart
« Reply #11 on: May 13, 2018, 04:30:17 am »
Send me a PM with the info.
Online Alex Nikitin
    • A.N.T. Audio
« Reply #12 on: May 14, 2018, 08:56:25 am »
-branadic-
Here is the result from my Keithley 181 over 5.5 hours - offset compensated, with +/-95nV input voltage applied for some of the time. Recorded by the K34465A at 1sec intervals from the analogue output, vertical scale is in microvolts.
Cheers
Alex
Offline branadic
  • Sounds like noise
« Reply #13 on: May 16, 2018, 06:58:41 pm »
Cheers
Alex
Thanks for the plot. Is there any difference in noise using digital data via GPIB or analog output plus a voltmeter? How did you manage to generate those 95nV?
-branadic-
Online Alex Nikitin
    • A.N.T. Audio
« Reply #14 on: May 16, 2018, 09:13:33 pm »
1) No difference. The (isolated) analogue output is generated by a 12-bit DAC, either from the top or from the bottom 3.5 digits. Each step is 1mV and clearly visible on a good meter, like the 34465A on 100mV or 1V range, so 1mV on the output from the bottom end = 1LSB = 1nV input on 2mV range.
2) From a divider - 21M/10R (just an accidental value) mounted in the plug and connected to 200mV output from the Keithley 617.  10 ohm in the divider is probably adding to the noise/drift as it is a simple 1% metal film resistor. I will re-build it with better resistors - probably a metal foil 10R, and a good quality 10M for 1/1000000 divider.
Cheers
Alex
« Last Edit: May 16, 2018, 09:15:14 pm by Alex Nikitin »
Offline maxwell3e10
« Reply #15 on: May 17, 2018, 01:25:45 am »
Cool data. I happen to be playing with the HP 34420A and will record similar data. Let's have a shootout of nanovoltmeters.
Offline TiN
  • Country: ua
    • xDevs.com
Nanovolts
« Reply #16 on: May 17, 2018, 04:55:07 am »
Mod then should rename the thread then :)
Online Alex Nikitin
    • A.N.T. Audio
Re: Nanovolts
« Reply #17 on: May 17, 2018, 08:51:18 am »
Perhaps it would be better to start a separate thread.
Cheers
Alex
« Last Edit: May 17, 2018, 11:40:26 am by Alex Nikitin »
