Author Topic: REVIEW - first impression of the Fluke 107 multimeter.  (Read 37484 times)
Offline zaptaTopic starter
« on: September 28, 2013, 07:58:55 pm »
Over the time I have accumulated few DMMs, a DT830 (no auto power shutoff), a  Metex 3860D (too complex, slow, low contrast) and a Tektronix DMM 150 (small but inconvenient), but wanted a single DMM to replace them all and my choice was the Fluke 107. I use DMMs occasionally for works around the house and car and for occasional electronics projects and hacking. I don't need fancy schmancy DMM that can survive an atomic bomb and has 10 digits of accuracy and traceability to the big bang, just a simple, reliable and no nonsense one.
The Fluke 107 is an emerging markets products, like the B17. It is compacts, has the basic functions (but no TRMS or uA), simple to use and very good display (with one caveats). I ordered it from Ali Express with shipment to the US and the transaction was smooth.
http://www.aliexpress.com/item/2013-New-fluke-107-F107-200g-handheld-Pocket-digital-multimeter-diode-test-Backlight-with-magnetic-Strap/1285231514.html
After playing with it a little bit, I am very happy with it "Two Thumbs Up!" and plan to put my other DMMs in the storage to simplify my daily life (one DMM is more than enough for me).
Below are pictures and comments regarding various aspects of the product.
The 107 fits nicely in the hand and construction solid. It has no rubber bumper and the yellow part just the plastic cover. It does not have a back stand so you put it on the table flat (it did come with some magnetic thing that may or may not be used as a stand, not sure, but I don't need it anyway). The front is raised so if it it falls face down it may hit the display and the rotary switch. Personally I don't care about that obsession with 'ruggedness' and prefer compactness over those thick rubber cases.  The selector switch is small but has excellent feel and definition. Labels are clear, button are rubbery with very good feel and audible feedback. The display always shows Auto Range and I could not figure out how to lock the range (if possible at all). Overall I like the size, feel and overall design.
Display has nice size, good contrast and is easy to read.
Backlight is excellent. It has auto off that you can disable. Same goes to the meter's power off.
The display has great contrast when you look from the front in a sharp angle (imaging the DMM flat of on the table in front or beside you). When the viewing angle gets to 90 degree and beyond is starts to fade (both with or without backlight). This is the main con I have with this product. I think the  viewing angle of the display was designed for real life viewing angle and this is not a real problem though it is unexpected and annoying.
Another picture of the display. Contrast is good. Backlight improves it even in a lighted environment.
Probes are high quality with thick and flexible wire. My only complain is that the wires are too long, 130cm from end to end. This defeats the compactness of the product.
Closeup of the probe.
The probes come with optional isolation.
Cables are thick yet flexible.
Batteries chamber. 2 x AAA. Easy to replace, just half turn of the lock screw.
Writing on the back. Mostly in Chinese. The user manual though comes also in real English
To access the internal, you need to remove these three screws.
The back cover and the battery cover.
Board is simple. Main chip has ad-hoc package to reduce cost. Some blast shields, also few on the back cover. Probe sockets are of the stamped type but look good to me. The two dark squares at the upper left corner are actually gold plated areas that touch the battery holder contacts of the back cover.
This looks like kind of fuzes Dave likes. The metal holders prevents that fuse from sliding along its axis.
Measuring the AC voltage at home. The TRMS Metex on the left. The GERMS (Good Enough RMS) Fluke 107 on the left. Looks like I leave in a perfect sine neighborhood.
The following users thanked this post: Marco1971
Offline Wytnucls
Re: REVIEW - first impression of the Fluke 107 multimeter.
« Reply #1 on: September 28, 2013, 08:56:12 pm »
Great pics, thanks. Meter seems to be well made with good soldering all round. I wonder which Chinese manufacturer got involved with the production of this little gem. Input protection is first class as per Fluke's reputation. Looks like 1 PTC, 2 MOVs and current limiting resistor on voltage input. Polyswitch (LF075) on + terminal of the batteries. (http://www.tripac.com.tw/pdf/passivecomponent/LITTELFUSE/1812L.pdf)
Big polyester kemet capacitor (http://www.kemet.com/kemet/web/homepage/kechome.nsf/weben/AD89911C0578AAC0852576AE007F3F15/$file/F9000_GenInfo_OrderERCaps.pdf)
It looks like the meter does without any voltage regulator, running at 3V, so probably won't like rechargeable batteries at 2.4V.
I can't see anything of dubious quality on the meter.
I don't see any adjustment pots for calibration, unless they are on the other side of the PCB, which may be a problem for self-calibration at a later stage.
All in all, pretty impressive so far.
« Last Edit: September 28, 2013, 09:13:49 pm by Wytnucls »
Offline Lightages
  • Canadian po
« Reply #2 on: September 28, 2013, 10:09:48 pm »
Thank you for the review. It looks like a nice little meter. I think that for the price though that the Amprobe AM-270 is a much better but although much bigger.
Offline Wytnucls
« Reply #3 on: September 28, 2013, 10:37:35 pm »
Most of the CEM and some UNI-T meters also have that quirky screen viewing angle. I learned to position them accordingly when in use. Not much of a problem really.
There is no manual range function. The meter is locked in auto range mode.
Offline echen1024
  • 15 yo Future EE
« Reply #4 on: September 29, 2013, 03:19:08 am »
Seems like a cute little meter. The FLuke 17B might be better for electronics though...
I'm not saying we should kill all stupid people. I'm just saying that we should remove all product safety labels and let natural selection do its work.
https://www.youtube.com/user/echen1024
« Reply #5 on: September 29, 2013, 05:06:45 am »
When you remove the battery cover, under the batteries, there was a label saying Calibration Label or something like that. Removing it exposed 4 gold contacts on the main board. I presume that the calibration is digital with some small non volatile memory somewhere. Don't know if the protocol is publicly available.
The calibration access port (with the original label removed, covered it transparent a tape).
The calibration contacts are seen here on the left side of the main board (wp6-9). They are dark in the picture but are nice gold plated pads in reality.
Offline retiredcaps
« Reply #6 on: September 29, 2013, 06:37:45 am »
Thanks for the excellent pictures.  Some comments.
1) The 10A current shunt looks like it has a bit of dodgy leaded solder?  It looks similar to the one on the Fluke 17B teardown as mentioned by Dave in EEVblog 344 (11:45 mark).
2) There is no range button as you noted.  In 99% of cases, it isn't a problem. The only time I needed to use the range button was measuring DCV on a malfunctioning part that was oscillating between 3V and 5V DC.  This caused my Fluke 83 III (4000 count) to display 0L continuously while it was trying to find the correct reading/range.
3) The input protection components such as the MOVs (K575) and green 1K fusible resistor look identical to the high end Fluke 87V.  The C1 cap is the same brand/manufacturer found in the Fluke CNX 3000.  The PTC is the same brand/manufacturer found in the Fluke 17B.
4) The test leads look like the TL75.
5) I'm glad you found the 107 meets your requirements.
Thanks again for sharing.  Now, I'm off to see if I can find who makes the COB IC.  I think it might be a FS9922, but some of the pins don't exactly match your picture.
Offline Amarbir[Lynx-India]
  • Country: in
  • Indian Dealer
    • Lynx-India - Visit Us For Not So Boring Electronic Instruments
« Reply #7 on: October 10, 2013, 06:54:35 am »
Sir ,
     Any headway on the COB IC ? .BTW this is brilliant photography .Would like to ask the thread started what camera he used
Regards
Amarbir Singh Dhillon [ Lynx-India ] , Chandigarh [ India ] - > www.lynxdealerstore.com , www.lynx-india.com
Indian Distributor For  [ Autoelectric , Sofitech , IDEOfy ,Peak Electronic Design [UK ] , Anatek And Creatronica ]
My Electronics Blog - > www.lynxchandigarh.com
Offline algorath
  • Country: at
« Reply #8 on: October 10, 2013, 03:16:26 pm »
kewl teardown, especially the pics are great quality :-+
Offline nathanpc
  • Country: br
    • Innove Workshop
« Reply #9 on: November 07, 2013, 04:17:40 pm »
Nice review and thanks very much for the awesome high res pictures.
If anyone is interested in another review, mjlorton just posted his one:
Offline shakalnokturn
« Reply #10 on: July 01, 2024, 10:53:43 pm »
Fortune semiconductor FS98O24
