Author Topic: Problems Updatging Agilent E4406A Firmware  (Read 1113 times)
Offline RCHRDMTopic starter
« on: May 07, 2019, 08:00:57 pm »
Hello
I have been trying to update the HP/Agilent E4406A VSA firmware using the updater program downloaded from Keysight on an XP computer.  After numerous tries, this is not working.  I can't update the rather old firmware.
Has anyone gone through this who could help?
Richard
Offline TK
Re: Problems Updatging Agilent E4406A Firmware
« Reply #1 on: May 07, 2019, 08:10:21 pm »
What error do you get and at what stage?  How is the VSA connected to the PC?
« Reply #2 on: May 07, 2019, 10:50:38 pm »
Here is a description of the process I am using and the messages.
Richard
Offline TK
« Reply #3 on: May 07, 2019, 11:00:04 pm »
Are you using a cross over cable?  If you are using a regular Ethernet cable, you need to use a HUB
Also try using the IP address 128.1.1.1 on the PC and 128.1.1.2 on the VSA
Netmask 255.255.0.0
« Reply #4 on: May 07, 2019, 11:02:58 pm »
Thanks.  Yes, I am using a cross over cable.
I will try those IP settings but it may be a couple of days before I can get to this.
Richard
« Reply #5 on: May 09, 2019, 03:59:13 am »
I tried those IP settings, but the updater still won't proceed.
Richard
