I haven't seen too many PCI-E oscilloscopes that I would call "cheap." Over the years at my job, I've bought ones from Gage, National Instruments, Acqiris and AlazarTech. All of them were several thousand dollars plus.
On the other hand, with an embedded scope card in a computer, you have to worry about 1) isolation (so you don't blow up your computer), 2) noise/interference from the PC itself, 3) lower quality power supply in the PC feeding the scope, etc. I'm sure the good scope cards take care of these issues and that's why the prices are a bit high for the casual user.
You might expand your search to include PCI/PXI digitizer cards. Most of them come with a demo-like scope application. Obviously, the cost of the digitizer is a function of number of channels, sample rate, number of bits, max bandwidth, etc.
