Author Topic: RTM3000 vs RTA4000 Noise  (Read 1607 times)
Offline YetAnotherTechieTopic starter
  • Country: pt
« on: May 29, 2021, 10:04:41 am »
Hello, as you know, one of the big differences between RTM and RTA series is that noise is a specified* parameter.
So I'm creating this post to enlist your help and get a comparison running.
To make the comparison valid regardless of the bandwith you have installed, it has to be done inside the DEMO app.
Let the scope warm up for 20min.
Perform the following commands:
Preset
Apps
Demo
Advanced
Noise
Start
Turn on Channels 2,3,4
Set them to 50 Ohm and 500uV, verify that bandwith shows as "full"
Press the "forward" arrow on the app window, until you reach the one titled "how much noise?"
set channel 1 to 500uV
press measure and add measure places 2,3,4 of type o-Std Deviation for channels 2,3,4
Reset statistics
the "how much noise?" window should still be showing, otherwise you exited the demo app!
once you reach above 2000 wave counts Print screen
Post results!
My RTM3004 is 100.54uV max  :)
1223124-0
*"Data without tolerance limits is not binding"
« Last Edit: May 29, 2021, 03:40:18 pm by YetAnotherTechie »
Online 2N3055
  • Country: hr
Re: RTM3000 vs RTA4000 Noise
« Reply #1 on: May 29, 2021, 02:35:11 pm »
Preset
Apps
Demo
Advanced
Noise
Start
Reset statistics
the "how much noise?" window show still be showing, otherwise you exited the demo app!
Post results!
(Attachment Link)
What bandwidth is that?
  • Country: pt
« Reply #2 on: May 29, 2021, 02:44:26 pm »
1GHz, as long as you don't touch too many buttons or exit the demo app.
Online egonotto
« Reply #3 on: May 29, 2021, 05:34:05 pm »
Hello,
my RTA has no Demo Noise.
Enclosed measures with 1 GHz and 200 MHz and 20 MHz with auto memory (6.06 KSa) and 20 MHz with 1 MSa
In sensitive range RTB, RTM and RTA are good. But in insensitive range the new LeCroy are much much much better.
I remember a paper from LeCroy about comparison of noise between different Scopes (LeCroy, Tektronix, Keysight, RS ). In this paper they wrote RTA noise ist too bad for the comparison.
Best regards
egonotto
The following users thanked this post: rf-loop, 2N3055, YetAnotherTechie
Online mikeselectricstuff
    • Mike's Electric Stuff
« Reply #4 on: August 11, 2022, 03:36:31 pm »
about the same on mine (not warmed up)
Day Job: Mostly LEDs
Offline graybeard
  • Consulting III-V RF/mixed signal/device engineer
    • Chris Grossman
« Reply #5 on: August 13, 2022, 12:58:38 am »
I wonder how the new siglent 12 bit model compares
