Author Topic: Just Upgrade my Rigol DS1054Z to the 4.04 firmware  (Read 29799 times)
Offline Towger
  • Country: ie
Re: Just Upgrade my Rigol DS1054Z to the 4.04 firmware
« Reply #50 on: May 07, 2017, 05:48:51 am »
Bitseeker, is correct.  I got a copy of it from Rigol a year or two ago.
Any chance you could PM a copy to me? I have a very early bootloader version on my scope, incompatible with current firmwares.
It will be Tuesday before I can have a look for it.
Offline LektroiD
  • If it didn't explode, I'm happy.
    • Music here
« Reply #51 on: May 07, 2017, 07:38:18 am »
Much appreciated. Thank you!
Offline Towger
  • Country: ie
« Reply #52 on: May 09, 2017, 09:13:09 am »
PM Sent.
Edit:
I downloaded the latest version and a fix for  0.0.0.13 is in it:
[Updated Contents]
v00.04.04.03.02  2017/02/06
     - Improved the LXI module
     - Fixed the freeze problem when upgrading based on the boot version of
       0.0.0.13
     - Improved the menu in the language of Traditional Chinese and Korean
     - Modified the failure when downloading waveform to the source module
     - Fixed bugs about reading the memory data through SCPI commands
     - Fixed bugs about Measure
     - Fixed bugs about Filter
« Last Edit: May 09, 2017, 09:21:52 am by Towger »
Offline ebclrTopic starter
« Reply #53 on: May 09, 2017, 09:24:28 am »
If is a bug, Isn't a hard one, I'm using on a daily basis as a scope, not a meter, and nothing hardly wrong
The following users thanked this post: Fungus
Offline phd0
« Reply #54 on: March 29, 2018, 07:02:21 pm »
[Supported Model]    All the MSO/DS1000Z Series Digital Oscilloscopes
[Latest Revision Firmware Date]  2017/03/24
[Updated Contents]
       0.0.0.13
Offline IAmBack
« Reply #55 on: March 30, 2018, 08:54:08 am »
It's one year old... I think it was already posted.
Offline ebastler
« Reply #56 on: March 30, 2018, 10:19:59 am »
Yes indeed. Two posts above, reply #52.  ::)
