Author Topic: Just Upgrade my Rigol DS1054Z to the 4.04 firmware  (Read 29782 times)
Offline pastra
Re: Just Upgrade my Rigol DS1054Z to the 4.04 firmware
« Reply #25 on: November 09, 2016, 02:04:39 pm »
Ok!
Thanks for both the link and the heads-up!
Offline Robuster
« Reply #26 on: November 09, 2016, 08:38:21 pm »
Do not update your scoop it will break your scoop if the bootversion is lower than 0.0.13
I had to send back my scoop for a repair. Scoop freezes or reboots at random.
Firmware was down graded by rigol.
« Last Edit: November 09, 2016, 09:32:42 pm by Robuster »
The following users thanked this post: edavid, Marcos
Offline madires
  • A qualified hobbyist ;)
« Reply #27 on: November 10, 2016, 12:10:51 pm »
So Rigol retracted the 4.04.01.01 silently without telling customers about the problem? I've got the 4.04.01.01 running on a DS1054Z with boot version 0.0.1.2. Luckily I haven't seen any issues yet.
Offline Stupid Beard
« Reply #28 on: November 10, 2016, 03:16:36 pm »
Same here. Hopefully it remains ok. Has anyone got a link to the original post(s) on the issue? I looked the other day but couldn't find it.
Online Fungus
« Reply #29 on: November 10, 2016, 03:34:45 pm »
Somebody found something that looked like the old jitter problem.
Not something to lose any sleep over.
Removing it while they investigate is a good sign. I means Rigol is taking their firmware very seriously.
« Last Edit: November 10, 2016, 03:52:58 pm by Fungus »
« Reply #30 on: November 10, 2016, 05:42:11 pm »
Oh, if that's all it is then that's fine. I thought it was something like the scope crashing hard and being unrecoverable.
Thank you  :-+
Offline BravoV
  • +++ ATH1
« Reply #31 on: November 10, 2016, 05:54:48 pm »
Robuster, where did you get that info ? (highlighted above) From Rigol ?
Online Fungus
« Reply #32 on: November 10, 2016, 06:00:51 pm »
Thank you  :-+
Here's the post:
https://www.eevblog.com/forum/testgear/new-rigol-ds1054z-oscilloscope/msg1066587/#msg1066587
Offline Robuster
« Reply #33 on: November 10, 2016, 10:40:21 pm »
Yes i have that info from Rigol. They flashed an older firmware version on my scoop and the problems where solved. They told me the new firmware gives problems with older pre bootversion 0.0.13. devices. They are working on new firmware to solve the probleem.
« Reply #34 on: November 11, 2016, 12:08:14 am »
Thank you  :-+
Here's the post:
Thanks. I think I did read that before, but I didn't twig because I was expecting something much more serious due to the post about Robuster's bricked scope.
Offline Robuster
« Reply #35 on: November 11, 2016, 07:49:18 am »
It was not bricked, mostly it freezes after one to two hours. Also the scoop reboots for no reason.
I thought it was a hardware failure so I send it to Rigol for a repair.
This is what I got from Rigol:
  Bootversion </= 0.0.0.12 doesn't work.
  Bootversion starting 0.0.0.13: New update works.
  Sometimes problems (randomly rebooting) occur with 0.0.0.13, R&D is informed and working on a new firmware.
Offline Skimask
« Reply #36 on: November 11, 2016, 07:54:31 am »
Don't worry.  It only affects his scoop.
You're scope will be just fine  :-DD
I didn't take it apart.
I turned it on.
The only stupid question is, well, most of them...
Save a fuse...Blow an electrician.
Offline alsetalokin4017
« Reply #37 on: November 11, 2016, 08:04:02 am »
All this stuff is confusing enough without getting the zeros and period points in the wrong places.
What we call "firmware" is what the scope calls "Software", and the scope's "Firmware" is actually something different, which is not changed by our "firmware" updates.
And if Rigol knows a method to roll back or install an earlier version of the "firmware" (actually the "Software") why don't they just tell us how to do it?
« Last Edit: November 11, 2016, 08:17:00 am by alsetalokin4017 »
Offline Robuster
« Reply #38 on: November 11, 2016, 09:25:53 am »
I have looked to the firmware/software they put on my scoop.
As you can seen it looks like a special version of 00.04.04.01.01 but then with version number 01.04.04.01.01
I hoop i can update if a new version from rigol is available.
Offline newbrain
« Reply #39 on: November 11, 2016, 09:35:54 am »
I see what you did there... :-DD
Offline 2N3055
  • Country: hr
« Reply #40 on: November 11, 2016, 09:51:54 am »
Lol mate, good one... :-+
Offline ProBang2
« Reply #41 on: November 11, 2016, 09:56:37 am »
@ Robuster
Sorry, I am just curious: How old is your scope?
Offline Robuster
« Reply #42 on: November 11, 2016, 10:03:34 am »
It's 3 years old.
Offline LektroiD
  • If it didn't explode, I'm happy.
    • Music here
« Reply #43 on: March 28, 2017, 08:42:48 am »
Is it possible to upgrade the boot version?
Before anyone says search the forums, I've already done several searches for this on here, but getting thousands of results, it's like trying to find a needle in a haystack.
« Reply #44 on: March 28, 2017, 09:38:50 am »
I have asked this question many times myself. I've even directly asked a RigolUSA technician, and I've never gotten a real answer. So as far as I am aware, the answer must be "NO", at least not by any means that we users have available to us.
It is also not possible, ordinarily, to "roll back" to an earlier version of the "firmware" once a later version is installed. However, looking at the posts up above, maybe there is a way to "trick" the scope into accepting an earlier version if it can be re-named to fool the scope into thinking it is actually a later version. Unfortunately no update method that I know of will change the Boot Version.
And since Rigol didn't change the Boot Version of Robuster's  scope they "fixed" up above... maybe there is really no way it can be done.
« Last Edit: March 28, 2017, 09:44:18 am by alsetalokin4017 »
Offline bitseeker
« Reply #45 on: March 28, 2017, 05:53:26 pm »
This is just from memory so take it with however many grains of salt you deem appropriate. There was once, way back when, a firmware update that included a boot update along with it. That's the only instance I recall seeing where the boot version was changed and it wasn't an independent thing you could install. It rode along with a firmware update, which I assume relied on whatever changed in the boot upgrade.
Offline Towger
  • Country: ie
« Reply #46 on: March 28, 2017, 08:07:19 pm »
Bitseeker, is correct.  I got a copy of it from Rigol a year or two ago.
Offline Neo2199
« Reply #47 on: April 02, 2017, 05:11:18 pm »
From the discussion above I am not sure what is the latest best firmware for bootloader version above 0.0.13 ?
Offline LektroiD
    • Music here
« Reply #48 on: May 07, 2017, 12:39:06 am »
Any chance you could PM a copy to me? I have a very early bootloader version on my scope, incompatible with current firmwares.
Offline Plasmateur
« Reply #49 on: May 07, 2017, 01:31:57 am »
Has anyone wrote some good labview VI's for this model? I can't seem to find anything on NI's website outside of the old VI's written in 2012
