Author Topic: TC1 lcr-meter transistor-tester fix  (Read 185167 times)
Offline SA
  • Country: bd
Re: TC1 lcr-meter transistor-tester fix
« Reply #375 on: July 14, 2024, 05:19:54 am »
Where to find the suitable fuse bits??
Offline madires
  • A qualified hobbyist ;)
« Reply #376 on: July 14, 2024, 08:45:16 am »
For m-firmwmare: edit Makefile (MCU, clock, programmer) and run 'make fuses'
Offline tedris
  • Country: tr
« Reply #377 on: July 27, 2024, 04:17:56 pm »
Hi i buy atmega324pa and i use usb programmer with  STC15L104W but not upload why? maybe in software chip not use?  is there software adaptape this?
Offline madires
« Reply #378 on: July 27, 2024, 05:11:14 pm »
Have you followed the guide on https://github.com/atar-axis/tc1-u4? If the STC15L104W can't be programmed maybe it's also also bad. In this case go for the two-transistor circuit modification.
Offline tedris
  • Country: tr
« Reply #379 on: July 27, 2024, 07:31:52 pm »
Hello, I don't understand, my Atmega processor is faulty, I will install software on it. Why am I dealing with stc15l104w? In the video I saw on the net, it was loading the Atmega processor. I tried as in the link provided, but I could not write stc in any way. I don't understand the other 2 transistor thing, it would be easier if there was a video or a card video. Thank you for your patient help. |O
Offline Kim Christensen
« Reply #380 on: July 27, 2024, 07:46:37 pm »
tedris, if you want to program your Atmega processor, then you need to connect the programmer to J4 instead!
Offline tedris
  • Country: tr
« Reply #381 on: July 27, 2024, 07:54:30 pm »
What will the connection pins be like? Can this be done with a programmer?
« Reply #382 on: July 27, 2024, 10:14:43 pm »
Not 100% sure, but I think this is the pinout for J4. (Got pinout from a TC1 schematic) Double check by ohm metering between J4 and the Atmel MCU.
(Reset, SCK, MISO, 5V, MOSI, GND)
What I did to program my TC1 was connect Reset, SCK, MISO, MOSI & GND to the programmer.  Then I temporarily jumpered out the test button to keep the unit powered up during programming.
« Last Edit: July 27, 2024, 10:20:53 pm by Kim Christensen »
Offline tedris
  • Country: tr
« Reply #383 on: Yesterday at 10:47:16 am »
I am using win11, could this be the reason? Were you able to do it in win11?
« Reply #384 on: Yesterday at 03:37:00 pm »
I used AVRDUDE on a Win10 machine using it's legacy serial port connected to a crude programmer that I temporarily built on a breadboard. (That programmer does not work with a USB --> Serial adapter)
Why? Because I'm cheap and haven't used Atmel chips for anything else.  ;D
Offline tedris
  • Country: tr
« Reply #385 on: Yesterday at 05:49:08 pm »
Can you send a picture? How did you do this, what did it look like? I bought 3 atmega324pa chips thinking that the legs would be short again. However, both programming it and finding the software is a serious problem. There is no software for T7, it will not return to its original state, I have no idea if other versions will work.
« Reply #386 on: Today at 02:28:25 am »
Sorry, I've already disassembled the breadboard and didn't take any pictures at the time. But it wouldn't have been much to see anyway. I simply built the programmer on the breadboard and connected it to my TC1 via grabber clips. A very temporary setup. I complied the binaries using WinAVR.
