If any of you have experience with JunTek PSG9080.
I want to know if it is possible to generate a trigger pulse at the start of each sweep with this generator. I know the SYNC OUT at the back will generate a pulse at every zero crossing of the signal but not at the beginning I have check that.
The reason is to get a frequency response curve on the oscilloscope.
Thank you, bye.
