Thanks @radiolistener for the teardown and the tests. Considering the price, this "Junktek" thing is really disappointing. Cheap as cheap can...
No dedicated sample memory, R-2R discrete D/A converter, (probably) marginal reconstruction filtering and no shielding at all. The power supply , especially the transformer, doesn't look too trustworthy regarding creepage distances, and performance-wise, -40dBc for the second harmonic is really less than stellar!
This generator may be okay-ish for hobby applications, but if I had to spend 170+ EUR plus possibly import VAT/taxes, I'ld rather spend 60 EUR more (all taxes included) and get Rigol's DG811 and hack it. Despite the size and the toy-like appearance, this will get you a much more mature instrument which can be considered to be the entry into the professional segment. Have a look
here for a set of teardown photos of my DG811. It becomes directly obvious that this generator plays in a different league.
If you don't want to spend that kind of money, the Feeltech generators are available for about half the money that the Junktek will set you back, and are pretty well characterized on this forum and, as the common opinion goes, are pretty useful as an entry level hobby AWG (with a mod applied or two...).
