Author Topic: Hello! New member with multimeter questions  (Read 8697 times)
Offline james_s
Re: Hello! New member with multimeter questions
« Reply #25 on: April 07, 2017, 03:33:31 pm »
Did it not come with reasonable leads?
The standard Fluke TL75 leads are under $25 brand new. They should work with most meters.
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #26 on: April 07, 2017, 04:20:02 pm »
Thanks for all the help.  After considering my needs right now (accurate measurement of components, biasing components based on frequency/voltage, and troubleshooting any issues on densely populated PCBs where there is little current or voltage), I felt that the UNI-T UT139C fit my needs at the best price.  I got it last night, and construction wise it feels a lot more solid than my Mastech.
Now it's onto finding some good test leads that don't cost $50...
Welcome and congratulations on your purchase! For test leads it is possible the UT139 already comes with decent ones. In your case I would instead invest in accessories such as alligator clips and grabbers to your test leads - something similar to what is shown in this eBay listing.
These things are of great help probing circuits.
Offline Lightages
  • Canadian po
« Reply #27 on: April 07, 2017, 04:26:11 pm »
The leads that come with the UT139C are pretty good leads. If you want a step up you trust our friend here on eevblog forums, Frankie, who has an ebay store. He has a couple of option:
http://www.ebay.com/itm/Digitek-Gold-Plated-Test-Leads-Probes-for-Multimeters-CAT-III-1000V-/171120395118
http://www.ebay.com/itm/Brymen-Silicone-Gold-Plated-Test-Leads-Probes-for-Multimeters-CAT-IV-1000V-/171162377470
Offline TimkoTopic starter
« Reply #28 on: April 07, 2017, 04:42:08 pm »
It comes with leads, but I am considering something very small as I am at some point going to start working with SMD parts and boards.  The last set of probes on my Mastech were a little too big to reach around some of the components, so I was considering something thinner.  But the leads with the UNI-T may be fine; I was hoping to find a way to connect the pinchers or alligator clips to the leads themselves.  With my Mastech, I had to use a double ended alligator clip to connect and it was sort of a mess.
Offline james_s
« Reply #29 on: April 07, 2017, 04:52:21 pm »
Well not to sound like a Fluke salesperson, but they offer a set of alligator clips that slip onto the standard probe tips.
I'm sure any number of other brands have similar offerings.
« Reply #30 on: April 07, 2017, 05:04:10 pm »
Oh cool!  I didn't realize that.  I was thinking that they had different connection wires for the ones with all the different tips (clips, pinchers, lugs, etc).  If that's the case, then all I need is a tip to slip on it since I have a decent set of leads.  Thanks!  I'm going to pick up some of those tiny pinchers and alligator clips to start.
Offline Fungus
« Reply #32 on: April 07, 2017, 07:10:22 pm »
http://www.ebay.com/sch/i.html?_nkw=multimeter+crocodile+clips
Offline tooki
« Reply #33 on: April 08, 2017, 09:26:15 am »
These from ProbeMaster have become my everyday probes, precisely for PCB work: http://probemaster.com/dmm-multimeter-test-leads/spring-loaded-test-leads/
Get the set, it comes with both spring loaded and fixed needle tips.
