Does anyone out there have a Gould Oscilloscope either a DataSys, 9500 or similar that has the 8 pin circular probe power connector on the back?
If you do I would really appreciate if you could measure the voltages on the probe power connector. I have a Gould Differential probe that I would like to use with another scope, however I can't use it because I don't know the pin-out of the probe power connector. The connector has 8 pins and the center pin is most likely ground as a black wire is connected to it, and various other colored wires connect to the remainder of the pins. The connector looks like this:
Much appreciated.
[img
http://forum.allaboutcircuits.com/attachments/con1-png.96342/[/img]
No response in 3 months, I thought I would resurrect this post to see if anyone has any input.
AFAIK, there is a German company which handles all the service for the Gould Nicolet instruments now. Dont know the name, but can look it up if you so desire. Maybe asking them will help
I did a google search, the only reference I found was Gould Nicolet Meßtechnik GmbH, however they seem to be closed.
If there is someone else please let me know.
Thank you
Thank you, I sent them an email.
If the language barrier is high, hit me up. tamhan aht tamoggemon ball com.
They are likely to have it or to know where to get it. But it is unlikely to be cheap...labor costs are insanely high in the BRD. Insanely, insanely high.
