Author Topic: ATTEN ATF20B teardown  (Read 52195 times)
Offline BeJay
Re: ATTEN ATF20B teardown
« Reply #50 on: January 27, 2013, 02:59:54 pm »
"There I fixed it!" - ok, so there is still a lot of flux on the board, and the bodge wires are a little big, but bugger me it works just like when I bough it... Cheers for the help fellas I'm off to make a protection circuit now ;)
« Reply #51 on: January 27, 2013, 04:05:56 pm »
Low impedance.........
Clean off the flux and it will look like it did straight from the factory.
What are you going to use for protection? A pair of  IDC clips and some 50mA sub miniature wire ended fuses to go in them?
Offline (In)Sanity
« Reply #52 on: January 27, 2013, 05:55:22 pm »
It's not what it looks like,  it's how it works.   Nice job.
Offline mbdemello
« Reply #53 on: June 08, 2014, 09:33:45 pm »
Hi!  I created a new topic on  ATF20B, regarding a ATF20B main-board (FPGA) failure and  would like to know if you have some schematics or block diagram of that generator.
Thanks and regards,
Mauricio De Mello
Offline Solder_Junkie
« Reply #54 on: October 09, 2015, 01:34:44 pm »
I came across this old thread recently and a general lack of info on these cheap Chinese function generators. There have been some on eBay UK for £188.77 inc tax and delivery (from a UK address). The price is as low as it gets...
Attached is the English manual for these, if it's of use to anyone considering one.
