Author Topic: IWATSU - new 8ch oscilloscope?  (Read 1922 times)
Offline mairoTopic starter
« on: December 03, 2020, 09:34:36 pm »
Any one have any info on this what it seems an 8ch scope from Iwatsu?
Edit - I just found my answer, it seems I was not searching in the official Iwatsu YouTube channel, which the top link seemed at first to be.. Interesting how it will compare with the other new 8ch scopes (at lower bandwidths) from Tek. and Keysight. Yokogawa (first one I think) and Lecroy also have 8ch scopes.
« Last Edit: December 03, 2020, 09:42:30 pm by mairo »
Offline DEV001
Re: IWATSU - new 8ch oscilloscope?
« Reply #1 on: December 03, 2020, 11:22:08 pm »
I found a news release on it and it appears to be brand new to the market.
Quoted prices converted to USD:
8 Channel $22,150.95
4 Channel $11,557.02
https://www.iwatsu.co.jp/newsrelease/2020/201130.html
Digital oscilloscope Wideband 1GHz, high resolution 12bit, maximum 8 channels DS-8000 series 6 models released
November 30, 2020
Iwatsu Electric Co., Ltd. (Headquarters: Kugayama, Suginami-ku, Tokyo, President: Toru Nishito) will release the DS-8000 series of digital oscilloscopes (maximum frequency band 1 GHz, vertical resolution 12 bits, maximum input 8 channels).
In recent years, devices such as power supplies, inverters, and non-contact power supplies incorporated in car electronics and home appliances have been reduced in size and loss by utilizing next-generation power devices such as SiC and GaN. In order to make these evaluations accurately, it is necessary to accurately measure high-voltage and large-current signals at high speed with high resolution. To meet these needs, we have developed the DS-8000 series of digital oscilloscopes. In addition, there is high demand for high-speed, high-resolution, multi-channel measurement in a wide range of fields such as mechatronics and physical measurement, and it is useful in various measurement scenes.
Product name
Digital oscilloscope DS-8000 series
Main specifications and features of the DS-8000 series
-Display: 15.6-inch Full HD With
 high visibility, you will not miss the details of the waveform.
-Easy-to-use user interface
Intuitive touch screen and buttons and knobs allow comfortable operation.
-High-speed startup for about 30 seconds
 After turning on the power, you can start using it without the stress of standby time.
-Number of analog channels: Select from 2 types of 4CH / 8CH
 Ideal for measurement of three-phase inverters and car electronics field equipped with multiple sensors.
-Frequency band: Select from 3 types of 1GHz / 500MHz / 350MHz
 Ideal for designing and debugging high-speed signal circuits.
-Maximum sampling speed: 5GS / s
 High-speed signals and steep signal changes can be reliably captured.
-Vertical resolution: Always
 captures minute changes contained in 12-bit (equivalent to 16-bit in high-resolution mode) large-amplitude signals.
-Maximum memory length: 120M points as standard equipment Achieves
 long-term waveform observation without slowing down the sampling speed.
-High-speed data transfer:
 Optimal for high-speed transfer of waveform data for simulation and improvement of tact time of production equipment about 15 times compared to our conventional products.
DS-8000 series model list
frequency band
Number of analog channels   Maximum
sampling
speed   Maximum memory length
1GHz   8CH   5GS / s   120M points
4CH
500MHz   8CH   5GS / s   120M points
4CH
350MHz   8CH   5GS / s   120M points
4CH
standard price
4CH model 1,200,000 yen (excluding tax) ~
8CH model 2,300,000 yen (excluding tax) ~
Release date
November 30, 2020
Start shipping
Mid December 2020
Contact
■ Customer
Sales Headquarters Second Sales Department
TEL 03-5370-5474
E-mail: info-tme@iwatsu.co.jp
■ Press
Public Relations Group , Corporate Planning Department
TEL: 03-5370-5112
E-mail: pr@iwatsu.co.jp
« Last Edit: December 03, 2020, 11:35:57 pm by DEV001 »
Offline Hydrawerk
« Reply #2 on: December 04, 2020, 11:39:48 pm »
Offline rvalente
  • Country: br
« Reply #3 on: December 05, 2020, 02:03:52 am »
Hey lecroy, another thing for you to rebrand!
« Reply #4 on: December 05, 2020, 10:31:55 pm »
Are these starting prices for the lowest bandwidths? If so, it will need to offer lots of software/probe features to be able to compete with the rest on the market right now.
