Author Topic: Keysight U1272A firmware file  (Read 1013 times)
Offline CaliaxyTopic starter
« on: December 05, 2020, 12:53:45 am »
I was planning to update the firmware of my Agilent U1272A, from ver. 1.0 to ver. 3.03.
I have a hard time downloading the firmware file from the Keysight website. The download never completes, it always provides an incomplete zip file. Same for the previous version, 2.04. I had no problem downloading the much larger data logging software and the drivers for the IR USB cable.
Does anybody happen to have a ver. 3.03 firmware file for U1272A and is willing to share it?
Offline PushUp
Re: Keysight U1272A firmware file
« Reply #1 on: December 05, 2020, 03:41:15 am »
I did the DL with jDownloader checking for any CRC-Errors, which is fine, but I don't take over any guarantee!  ;)
Unfortunately the froum has a 4MB limit: "Your file is too large. The maximum attachment size allowed is 4000 KB."
Therefore I can only upload to Rapidgator:
https://rapidgator.net/file/659c0c8a3ef898cfa9a9d1b0535d272f/U1271A_U1272A_Firmware_Update_Software_Version_3.03.zip.html
By the way: You have to go manually into the "Keysight Technologies" folder within "Program (x86)", in order to start the software.
Do a reset of the DMM before you do anything, check the com port and baudrate before doing the update process!
I did the update for both U1272A and U1273A, but it is long time ago - be careful!  :-+
« Last Edit: December 05, 2020, 03:50:14 am by PushUp »
The following users thanked this post: Caliaxy
« Reply #2 on: December 05, 2020, 09:04:56 pm »
Worked like a charm. Thank you so much!
