Haven't been following the talk on the forum lately (life, job...) so I apologize if there have been some recent talks on this topic.
I have a need for a low noise power supply, preferred resolution of 1mV/1mA, that has a fairly small footprint.
No need to go above 5V, but low noise is an imperative, since I want to be confident when testing at near POR voltages.
As far as I know uSupply died (was promising), and there are some IOT power profilers that still need an external PSU. With these devices I'm not sure how much noise propagates if the external supply is switching...
Battery simulation would be a big plus, but that skyrockets the price and usually has a bigger footprint. High res. logging is a plus as well, but not as much...
If you have any good suggestions they're welcomed here. Not sure I have a certain price point in mind, because I'm a sucker for "...but if you just add $100 you get this feature...", so I need to analyze what I can get at each price point... but not sure I'd go above something like 600-700usd, no matter what fancy features it has...
