IT-M3100 series breaks through the traditional tech limits, in the ultra compact size of only 1U Half-Rack, the unit can not only output high power, but also has high performance and versatility. It supports the master-slave parallel mode. The full range of models support multiple stacking and parallel connection by handily designing "leg" plug-in. Fit with rack mount kit to achieve the perfect use. IT-M3100 series consists of 12 models, providing 6 voltages grades, and can be combined to achieve a variety of output power. It has a flexible modular architecture, independent multi-channel design, and supports synchronous operation. Users can configure each channel according to the test requirements of DUT, up to max. 16*16 channels, to meet the needs of customized solutions. It has a wide range of application values and is suitable for a variety of applications such as research and development, design verification and automatic test systems intergration.
These are not huge rack mount supplies. It seems to me half width 1U units. I doubt these will be quiet though.
Quote from: nctnico on May 30, 2019, 10:45:03 pmThese are not huge rack mount supplies. It seems to me half width 1U units. I doubt these will be quiet though.Huge compared to a regular bench supply. I don't think too many people here care about the size of their rack supplies (a normal rack is what 25 or 42U?).The youtube video is it sitting in someones hand.
