Author Topic: ZD-985 Repair trick (videos) using Anemometer  (Read 573 times)
Offline SegasonicfanTopic starter
« on: June 17, 2020, 08:33:33 pm »
Hi everyone,
I made some ZD-985 repair videos thanks in part to the help of older posts on this forum.  Specifically, I wanted to share a cool trick for cleaning out the nozzle, and that is if you swap the hoses on the pump you can get to blow air out instead of sucking it in.
Hopefully this helps someone else out:
