Hello all,
I have posted this on the Tek group on groups.io, but I am posting it here too for a wider audience.
I had a perfectly functioning 2467B scope (1989 vintage). After reading about possible loss of calibration data due to the NVRAM battery dying, I decided to put in a new battery (mine is the older version, below 50000 serial #) which has the battery separate from the NVRAM. The battery had a date code of 2689, so the battery is 35 years old. I did hook up a backup battery before removing the Lithium battery and confirmed that pin 28 of the RAM chip had at least 3 V on it from the backup battery after removal of the original battery. After putting in the new replacement battery, I also changed out the 4 electrolytic capacitors on the A5 board. When I put the scope back together and fired her up, I got the dreaded " Test 04 Fail 13" message indicating corrupted or lost calibration data. Not sure how this happened since I hooked up a backup battery before removing the original battery. So, the very thing I was hoping to prevent happened by my being proactive!
Before doing all this, I had made a copy of the RAM contents by running through the Exercise 02 option, so I have the original calibration data available. My question is: how to write this data back to the RAM? (my scope does not have the GPIB option).
I look forward to your suggestions and hope to get this fine scope functioning again!
