Author Topic: Is this a real Hioki meter?  (Read 4034 times)
Offline cakekellyTopic starter
Offline edavid
Re: Is this a real Hioki meter?
« Reply #1 on: May 16, 2017, 05:43:57 pm »
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #2 on: May 16, 2017, 11:36:33 pm »
It's a persistent scammer.  See the other thread: https://www.eevblog.com/forum/buysellwanted/scam-warning-wtc999good-sellers-selling-uni-t-meters-cheap-on-eaby/
the seller linked by the OP is fitting2011, not wtc999good-sellers. and the item price is US $86.89, not $10...
Offline retiredcaps
« Reply #3 on: May 16, 2017, 11:45:45 pm »
The Hioki DT4211 is likely a DER multimeter rebadge of some sort.  See
https://www.eevblog.com/forum/testgear/hioki-42114212-quality/
Offline boggis the cat
« Reply #4 on: May 16, 2017, 11:57:56 pm »
I have just been working completed a cal procedure for the Hioki DT4212.  These are made in Taiwan, and are comparable in quality terms to the Japanese made models.
There are some odd limitations -- 1 V diode test, frequency only works for voltage -- but Hioki seem to have some oddities.  If interested, search for the manual for the Hioki DT4212 (also covers the DT4211) and check the specs carefully.
Edit:
Forgot to add that these models are now obsoleted.  No replacements seem to be available as yet, which is a bit odd.  (Hioki oddness...)
Edit 2:
There is a Hz setting available for voltage and current.  The separate "Hz" position is what appears to be specified, however I would assume that the same spec can be applied to the voltage and current settings with the Hz mode set (within the 40 through 500 Hz limitations of the settings, in this case).
« Last Edit: May 17, 2017, 04:48:27 am by boggis the cat »
Offline edavid
« Reply #5 on: May 17, 2017, 12:35:47 am »
The listing the OP linked to was taken down.  It was a $9.99 listing like this: http://www.ebay.com/itm/HIOKI-DT4211-DIGITAL-MULTIMETER-DT4211-0-5-Accuracy-Brand-New-DT-4211-/262976452231
Offline ciccio
  • Designing analog audio since 1977
    • Oberon Electrophysics
« Reply #6 on: May 19, 2017, 12:22:00 pm »
I accepted the risk of losing 9.99 US dollars, and placed an order on E-Bay on thuesday, may 15.
The order was confirmed the same day, PayPal sent me a receipt for the payment, then after two hours I got a message from EBay stating that the post was cancelled, but after 36 hours I goat an EBay message stating that the item was shipped. I even got a shipment code (RU724121427CN), but don't know where to search for it..
Let's see what will happen, delivery is stated from june 12 to  july 7.... full of time to open an EBay - Paypal dispute.
Strenua Nos Exercet Inertia
I'm old enough, I don't repeat mistakes.
I always invent new ones
Offline joseph nicholas
  • Country: mx
« Reply #7 on: May 19, 2017, 01:46:19 pm »
I did the same thing as the previous post with the exception of not receiving a conformation that the meter was shipped.  Tried to contact the seller several times with not response.  I can only wait until the time for delivery lapses and get a refund from ebay.
Offline CustomEngineerer
« Reply #8 on: May 20, 2017, 06:49:58 pm »
Understanding that its only $9.99, why would you even waste the time. Just look at the sellers feedback, its obvious exactly whats going to happen. Why would you expect anything different?
