I use the Soresen XTS quad. It's four discrete supplies in one chassis. The individual supplies are available in 7.5V 8A, 15V 4A, 30V 2A, 60V 1A, 120V 0.5A. Any combination of those five is available in the quad units. Each unit has a large LED readout for V and I to 3 digits.
Accuracy is <= 1mV, and I've tested it. Each unit can be configured with GPIB, serial, and/or Ethernet. Each discrete unit has front tellurium-copper bananas, including 'sense', and the rear has output and sense screw terminals.
There is no indication for 'set' values, except the display. You just fiddle with the knobs until it's set the way you want. The V pot is 10-turn and the I is 1-turn. The supplies are linear, fanless, and programmable via PC connection.
I have (2) XTS-15-4 quad supplies.
You can also put the individual supplies in serial for combined voltage, or parallel for combined current. The unit I'm running has been up for at least 2 years, 24/7. These machines have a US Military specification.
New they are prohibitively expensive: 2,800.00USD range! But on eBay they go for ~300.00USD for the lower voltages, up to ~1,000.00USD for the higher ones. The discrete units are also sold individually.
I purchased a 60V 1A single for my Dad for his birthday. These supplies are made for industrial and military use. They all bear the name Sorensen, but have been manufactured by several companies, including Raytheon, Xantrex, and Ametek.
The Raytheon are the oldest. The ones I have are Xantrex. The newest are Ametek. For linear supplies they're pretty efficient, but there's only so far you can go with that. And <=1mV is not spectacular, but then you're getting into voltage references.
I used to have PSUs all over the place. After I found these I got rid of most of them. And, if your looking for a great UI for any instrument, connecting it to a PC is going to give the BEST UI. However, software can be pricey!
