As it currently stands, you will need an appropriate JTAG debugger.Smgvbest has an excellent how-to here https://www.eevblog.com/forum/testgear/sniffing-the-rigol's-internal-i2c-bus/msg569236/#msg569236 , far better than my attempt a few posts earlier which had been written some weeks after doing it (for reference here https://www.eevblog.com/forum/testgear/sniffing-the-rigol's-internal-i2c-bus/msg566312/#msg566312 )Smgvbest says that the debugger she used is no longer made. I used an Olimex ARM-USB-OCD-H which is still available.
