hello,
i have rigol ds1054Z on its way to my home, and i bought it with all options unlocked except BW 100MHz.
I read the forum and know how to activate it, but have one question.
If i want to restore it on its original state like it was from the first day- all options unlocked but with 50MHz what should i do ?
I am asking it in case if i need to send it for repair .
thanks in advance
You would have to uninstall all options via an SCPI command, then reinstall the "legal" ones by generating the right key via Riglol. There are various posts here describing the details; search the forum for for "SYST:OPT:UNINST".
Along the lines of uninstalling options...
- I purchased my DS1074Z (70MHz) scope in Feb 2014.
- Throughout all the discussions I have read here, I have never seen how the scope determines if it is a 50MHz or 70MHz version. The option bits I have seen only allow you to select the 100MHz option.
- I'm curious if anyone knows if there is a 70MHz option? Not that I would ever go back.
As far as uninstalling all hacked options in order to send the scope back to Rigol. If the scope is in a state that it needs to be sent back to Rigol for repair, it IS UNLIKELY that you will be able to uninstall any options. (i.e. the scope is broken).
I believe Rigol is now selling the DS1054Z with ALL options except the 100MHz enabled.
Also from what others have said and the fact that Rigol has not made any effort into blocking the hack, I do not believe they care if it is hacked or not. I would imagine at this point that they expect it to be hacked. Has anyone here returned their scope for repair? What options were enabled when you got it back?
Just unlock the 100MHz option and do not worry about it.
