Author Topic: is Rigol DS1054Z still hackable ?  (Read 72996 times)
Offline DG41WV
  • Country: lk
Re: is Rigol DS1054Z still hackable ?
« Reply #25 on: June 07, 2018, 03:41:00 pm »
Back to the question of the OP, yes the Rigol DS1054Z is still hackable.
For deeper questions like:
- does the bandwidth hack actually do anything other than show a placebo number on the display? or
- what is the meaning to life, the universe, and everything
the answer is 42.
actually 42 is the Answer to the Ultimate Question of Life, the Universe, and Everything. no one knows what was the question, just the answer.
and for the 100MHz hack wouldn't calibrating the scope solve it?
Offline DG41WV
  • Country: lk
Offline Adrian_Arg.
  • Country: ar
Offline TheNewLab
« Reply #28 on: July 05, 2018, 01:38:38 am »
Just to put it out there. I have just bought a Rigol 1054 because of the posts on this site to hack.
Mine arrived with everything activated EXCEPT the 100MHz feature.
I was really hesitant to go ahead and do the hack because of the pre-activation and upon careful inspection the firmware version was more recent than anything i could find.
After a time I just said WTF, let's see. I used the links on this forum.  entered the the code and it worked fine. Did not lose the other pre-activated features and it did add the 100MHz feature.
By-the-by, I actually used an iPhone 4s to get to this forum, followed the link to the Keygen site. carefully read the activation code generated. (made some screenshots) and then did the hack...
There has been discussion that Rigol has intentionally allowed people to hack this model..I think I have also mentioned it. It seems that Rigol is now selling them all pre-activated for all except the 100MHz because I carefully inspected the packaging. it was clear, that the it was still originally shipped from Rigol.
However don't blame me if your effort gets screwed up...it is always at your own risk,
Cheers!!
Offline alsetalokin4017
« Reply #29 on: July 05, 2018, 02:57:33 am »
It has been confirmed that the 100MHz unlocking does increase the bandwidth of the scopes sold since the beginning, that only included the other options for the trial period.
I'm wondering if that still holds true for the current releases that come with all the options unlocked except for the 100MHz hack. Does the bandwidth hack still have the same effect on the new scopes as it did on the older ones?
Offline ebastler
« Reply #30 on: July 05, 2018, 04:54:15 am »
Nothing mysterious about this. Rigol has offered the scopes with an "all options included" bundle for several months now -- maybe half a year, from memory? This was also discussed in multiple threads on this forum.
But the 100 MHz bandwidth upgrade was never offered as a field upgrade option, and is not included in the bundle either. Why would they sell you a DS1104Z for a DS1054Z price, after all?
Offline TheNewLab
« Reply #31 on: July 06, 2018, 03:34:56 am »
no the total price was just over $200. a Rigol 1054 with all official upgrades except the 100MHz. The MHz was because I followed the forums here and went to the keygen site with small screen iPhone..used "expand to enter serial # and read the activation code for the 100MHz. used screen shots to save then did the code ting on the scope.
Sorry, I seem unable to keep my posts brief..
Online Fungus
« Reply #32 on: July 06, 2018, 07:47:29 am »
Since December (for Christmas).
Offline Doogs
« Reply #33 on: August 25, 2018, 01:20:44 pm »
Just updated my new 1054z using the 100MHz option and it's showing as a an 1104z in Sys. Inf. Seems the Gotroot hack is still in functional as of 8/25/18.
ETA: software ver. is 04.04 SP3 and board ver. is 0.1.4.
Does this mean I'll need new probes?
« Last Edit: August 25, 2018, 01:25:12 pm by Doogs »
Expensive Tastes and Poor Choices!
Offline Adrian_Arg.
  • Country: ar
« Reply #34 on: August 25, 2018, 01:43:17 pm »
no, the probes are up to 150mHz, that's what the info sheet says.
Offline Terry01
  • Country: scotland
« Reply #35 on: August 25, 2018, 08:23:48 pm »
I've been going to do mine but haven't got round to it yet. Mine has everything upgraded right from the factory except the 100Mhz upgrade. I may do it over the weekend!
That's good to know the hack doesn't affect any of the stuff done already at the factory. I did wonder about that too.
Sparks and Smoke means i'm nearly there!
Offline elonSmokes
  • Country: br
« Reply #36 on: September 25, 2018, 12:28:49 pm »
I had this same question, but I felt confident enough to buy it, because nowadawys the 1000z series comes with all the decoders, triggers etc. excepti for the 500uV / division and 100Mhz  BW (I'm not sure if actually enlarge the bandwidth), but I've heard it has almost the same hardware of 1100 series (I didn't check this info) - if someone knows that, please confirm.
Anyway,
I've tried to hack it using the website, but it didn't work. I also used different browsers, but they generated the same key.
So, what did was download the .zip from the website and run it locally.
As the only 2 features that were not yet unlocked in my Rigol 1054z 04.04 software version are:
 - 500 uV / division
 - 100 Mhz BW
I generated one key at a time to unlock each feature, using the .exe (downloaded):
.\riglol.exe yourpartnumber DSBA     (to unlock 500uV)
.\riglol.exe yourpartnumber DSEA     (to unlock 100Mhz)
Now it works fine.
Offline elonSmokes
  • Country: br
« Reply #37 on: September 25, 2018, 12:30:35 pm »
I had this same question, but I felt confident enough to buy it, because nowadawys the 1000z series comes with all the decoders, triggers etc. except for the 500uV / division and 100Mhz  BW (I'm not sure if actually "enlarge" the bandwidth), but I've heard it has almost the same hardware of 1100 series (I didn't check this info) - if someone knows that, please confirm.
Anyway,
 - 500 uV / division
 - 100 Mhz BW
Now it works fine.
Anyway,
 - 500 uV / division
 - 100 Mhz BW
Now it works fine.
Anyway,
 - 500 uV / division
 - 100 Mhz BW
Now it works fine.
Online Fungus
« Reply #38 on: September 25, 2018, 12:33:50 pm »
It's exactly the same hardware.
Unlocking 500uV is a bad idea, the hardware doesn't support it and it's easy to select accidentally (annoying!)
Online Fungus
« Reply #39 on: September 25, 2018, 12:41:36 pm »
You can remove upgrades by connecting to it with a LAN cable and using Telnet (port 5555). Then type:
:SYSTem:OPTion:UNINSTall
Then use Riglol to generate a key with DSER options, that's everything except 500uV. Over LAN you can install keys easily with:
:SYSTem:OPTion:INSTall RDXXXXXXYOURKEYXXXXXXXXX
Offline Harjit
« Reply #40 on: November 11, 2018, 05:43:38 pm »
How did you get it for just over $200?
Offline kynrek
« Reply #41 on: September 25, 2019, 09:09:15 pm »
I just wanted to let folks know that the DSER codes does still work as of today with firmware revision 00.04.04.04.03 for the DS1054Z :)
The following users thanked this post: Gandalf_Sr, Fungus
Offline MatthewTx
« Reply #42 on: October 17, 2019, 07:07:33 pm »
How did you get a 6% off from Tequipment.net? I'd love to have that coupon code!
Offline Gandalf_Sr
« Reply #43 on: October 17, 2019, 11:41:42 pm »
Go check out this thread https://www.eevblog.com/forum/testgear/eevblog-members-discount-at-tequipment/msg2734954/#msg2734954
It used to be that they didn't want it posted on the forum but they seem to have posted it themselves recently.
If at first you don't succeed, get a bigger hammer
Offline ebclr
« Reply #44 on: October 18, 2019, 06:51:56 am »
" These are NOT Keysight, Tektronix or Rohde & Schwartz instruments.  They are built to sell at the lowest possible price.  Lots of people have "hacked" the scopes to be "100 MHz BW".  I've not seen anyone demonstrate that the result actually has that bandwidth.  "
In fact, you are wrong, many people already showed that the bandwidth is much better than 100Mhz,  my unit does 160 Mhz at 3 dB, don't talk watch you don't know, just because you believe that expensive brands do anything better just because they charge more for less.
The following users thanked this post: Jacon
Offline paulc_6969
« Reply #45 on: November 18, 2019, 10:59:07 pm »
Answer is "YES". Just done.
With software version v00.04.04.04.03  2019/05/30 (aka 00.04.04.SP4) the hack works.
* First, power the scope from an UPS, if you don't feel lucky
* Advice: first uninstall all options via telnet with:
    :SYSTEM:OPTION:UNINSTALL
* Do the firmware upgrade as by instructions
* Reboot
* Use riglol to generate the DSER key for your scope's serial
* NOTE: copy option key with no dashes!!
* Do the DSER hack via telnet:
    :SYSTEM:OPTION:INSTALL <DSERoptionkeyfromriglolnodashes>
* The scope will beep
* Check via telnet the system info with  *IDN?
    You will notice the model has changed to DS1104Z
* Reset all settings with  *RST also by telnet
* Check the option from scope menu - should be all <Official>
* Warm-up for 30 minutes and do the self calibration
-- That's all ---
I can confirm also that the "100MHz" option works and MODIFIES the bandwidth.
In fact, it is only a one pole 50MHz low pass filter switched on or off.
The ADC and the DSP are unmodified, the scope is made for 100MHz anyway.
Checked with square waves from 20 to 80 MHz and they change for the better, including rise/fall times.
If you really need more than 30Mhz, buy a decent set of probes (300Mhz minimum = 3x scope bandwith rule)
The default probes suck for over 50MHz.
Enjoy!
Offline Masimo
« Reply #46 on: December 27, 2019, 05:38:07 am »
I bought a Rigol DS1054Z on 12/19. NO it will not unlock. Features work, but 50 MHz is it. All sorts of errors from keygen. Most interesting is the only key code I got had several embedded 1's in it. Keypad entry on scope has no 1 position. It is 2 thru 9. So it all stops. Have tried different browsers, XP, Win10, Chrome, Firefox. Win10 generated the "1" containing code. All others total fail. Any thoughts? Uses late firmware. Bought thru Amazon, box factory sealed.
Online Fungus
« Reply #47 on: December 27, 2019, 05:45:17 am »
What keygen? What errors?
Why not use the online one: http://www.gotroot.ca/rigol/riglol/
(code should be DSER)
Offline BravoV
  • +++ ATH1
« Reply #48 on: December 27, 2019, 06:04:30 am »
Here in this forum alone, we've seen maybe hundreds of similar problem that unable to hack it, but yet all were solved nicely as all caused by silly/tiny mistakes, the devil is in the details.
Offline Masimo
« Reply #49 on: December 28, 2019, 02:38:24 am »
I have used the gotroot web page. I have also downloaded the code and run. No luck. I get a response saying the key generated is too long. No idea why. I have very late firmware. It is 00.04.04.SP4. It is like the format of the serial number is too long. It is 14 characters long. Keygen does not like it.  Serial is same, on screen, and back of scope. I can clearly read it. Options came unlocked, no time limit EXCEPT BW is 50 MHz. That is the problem. I have never even generated ANY key, from this web address, gotroot you mention. Board version is 0.1.4 Any suggestions appreciated.....Max
