when I trim zero offset in voltage mode then the current mode offset will be 1000fA+
LMC662 was purchased from Mouser.
I already changed input JFET pair to LMC622 in some other device which has identical input schematic, the result was similar - offset in voltage measurement mode.I assume this replacement is not suitable for this type of devices, it breaks voltage and ohms modes as well. The offset voltage of 20mV cause resistance never going to zero even with zero check enabled, it shows 200 Ohms. Amps works great on other hand, stability and settling time is much faster with OP Amp mod.
