Author Topic: Power supply with log capabilities  (Read 1140 times)
Offline cio74Topic starter
« on: January 08, 2014, 10:10:54 pm »
Hello,
I'm after a power supply which can be programmed with a list of voltage and max current, ideally with the voltage max of 60 volts and 2 amps min. There a are a few, what I need extra is the ability to create a log with the recorded values; or just the ability to save the recorded values as csv or similar, then I can produce a graph.
I am not sure if Rigol 832A is a valid option (use outputs in series to get desired voltage), it seems buggy? Perhaps I'm wrong and just minor glitches?
I am also considering:
Tektronix PWS4602 (it has a list but not sure if it does produce logs)
AIM-TTI INSTRUMENTS - QL355TP (this one seems programmable)
Any opinion on the above or a recommendation?
Thanks.
