Author Topic: Intermittent BNC Cable  (Read 3727 times)
Offline tony3dTopic starter
« on: January 08, 2014, 06:29:52 am »
I ordered a MALE BNC TO BNC cable, and found out its intermittent, and only make contact when I pull on the ends slightly. Yet, when I check it with on continuity tester it's fine. What gives? It's a cheapo from eBay. The only thing I can figure is the the connectors are out of tolerance.
Lurch
  • Guest
Re: Intermittent BNC Cable
« Reply #1 on: January 08, 2014, 06:33:12 am »
Cheap BNC connectors are total shit. I have fitted thousands (mostly decent ones :)) so speak from experience.
Offline VK5RC
« Reply #2 on: January 08, 2014, 06:41:16 am »
Don't BNC come in both 75 and 50 ohm varieties,  that don't fully mate,  or can even damage?
Lurch
  • Guest
« Reply #3 on: January 08, 2014, 06:44:59 am »
Physically they are exactly same, from a mating faces POV.
Online vk6zgo
« Reply #4 on: January 08, 2014, 07:23:56 am »
You're thinking of "N" connectors.
Offline VK5RC
« Reply #5 on: January 08, 2014, 07:28:00 am »
Lurch and vk6zgo, thanks for the info,  regards
Offline JDubU
« Reply #6 on: January 08, 2014, 07:45:00 am »
They have been physically compatible since 1978 (1978 standard IEC 169-8).
Online vk6zgo
« Reply #7 on: January 08, 2014, 09:53:43 am »
They pretty much always were,that just formalised it!
Offline ConKbot
« Reply #8 on: January 08, 2014, 01:17:41 pm »
Crimp pins meant for (presumably) RG-58 which is multi-stranded, crimped onto a solid center conductor of RG-58ish cable can give nice intermittent joints like that.  That or the shield breaking off from flexing, but if you can see into the back of the crimp, then you can inspect that.
« Reply #9 on: January 08, 2014, 09:15:32 pm »
I ordered a new Cable from Saelig, and it works great!
